Lifted truck how much can I tow? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 14 (permalink) Old 01-03-2008, 11:09 PM Thread Starter
Mustang mike 93's Avatar
With the mods in my sig what can I safely tow?
2000 F250 PSC CC 4X4 Dp tuned Edge EVO2 60,80,120 tunes, AFE2 Cold Air, MBRP Turbo Back exhaust, 6 inch Fabtech lift 35 inch BFGs ATs.
Mustang mike 93 is offline
post #2 of 14 (permalink) Old 01-03-2008, 11:13 PM
Going Crazy
badluck_early99's Avatar
Send a message via MSN to badluck_early99
Re: Lifted truck how much can I tow?
well if the springs are rated for the same as stock then what ever your stock max is... We tow all the time with lifted trucks up to and over what the truck is rated for.. its really only limited by that those springs are rated for and what your comfortable with
1999 F250 PS 6spd, 37x12.50x17 ProComp Xmud, 06 Grill & Lights. DP tuner, Terminator Hpops, Garrett 42, Casserly B codes, FASS Fuel system by DI, H11's, ITP Reg Return W/Bowl Delete, Sknab 6oh Intercooler, DIY Intake, 4'' Exhaust, Itp OBA, Autometer boost and pyro, , ccv
-Richard-
badluck_early99 is offline
post #3 of 14 (permalink) Old 01-03-2008, 11:16 PM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
Running a 4" lift and 37's I have towed 14k or more...
Joe
CSIPSD is offline
post #4 of 14 (permalink) Old 01-03-2008, 11:19 PM
Going Crazy
yea with mine basically 4'' and 37's ive gone up to 16k..... on my buddies evil truck.. dodge.. with 6'' and 37's he tows 16 to 18 on a daily basis, hes rear leafs are starting to sag a little now but the truck handles perfectly fine
-Richard-
post #5 of 14 (permalink) Old 01-03-2008, 11:20 PM
Hated by All
Fast_Ashley's Avatar
6" lift 42" tires and I tow right around 15k weekly......
PARIAH
2001 F-350
Resurection has begun.....
Fast_Ashley is offline
post #6 of 14 (permalink) Old 01-05-2008, 12:50 PM Thread Starter
When I bought the truck the guy had stock springs in the back with three stacked blocks. I did not feel very safe with that setup so I installed some Fabtech 6 inch long travel springs. Will this work? Or what should I get? I am not a big fan of the trucks that sag in the back I like it level or a little raked in the back.
post #7 of 14 (permalink) Old 01-07-2008, 04:00 PM
CSIPSD's Avatar
Aftermarket springs will do that most of the time when towing, because they eleminate the factory overloads...
Joe
CSIPSD is offline
post #8 of 14 (permalink) Old 01-07-2008, 04:08 PM
HP Junky
If it sags when you tow, throw on a set of airbags and you're set.
RockinJW is offline
post #9 of 14 (permalink) Old 01-08-2008, 02:39 AM
<- Sums it up
strokin_early_99's Avatar
You should be able to tow up to your max towing capacity, just as you could at stock height. I tow a lot. I added air bags to keep it from squating with a load on it. My truck has a 4" lift and I run 35's.
Early99 CC LWB 4X4
Updated B codes, Modded H2E, Big oil, half filled block, studded, John Wood 4R100. 232K miles
Tows like a champ!
"Damn Larry, he passed us like a freight train passing a hobo!"
--Lisa P.
Just sold to Larry
2-17-2019: 97 CC LWB 4X4 7.3 with full banks kit, John Wood E4OD. 139K miles
strokin_early_99 is offline
post #10 of 14 (permalink) Old 01-08-2008, 02:43 AM
Don't EFN worry about it
Aljay's Avatar
What are the tires rated for all you guys with 35-40+ tires lol ?????? Does it walk due to the tall sidewall ?
Tuned by T Wildman
Aljay is offline
