2012 Tone ring change? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 08-28-2016, 12:02 AM Thread Starter
Is there any change other than plug location on a 2012 rear axle? Im wanting to put it into my 02. It has the electric locker.
02 crew cab 4x4
61 scout 80 rock crawler
plug ugly is offline
post #2 of 2 (permalink) Old 08-28-2016, 02:50 AM
Moderator
Sbluke55's Avatar
Re: 2012 Tone ring change?
The rear axle is 3" wider than your current axle. Also I believe the axles has the abs sensors at each wheel vs the center section. So you won't be able to get the rear to read correct.
01 f-250, Standard
Sbluke55 is offline
