Air compressor install questions - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 06-19-2016, 02:29 AM Thread Starter
duxpsd's Avatar
I was given a small compressor I know I will need an inverter to run it. Im just not sure what size or what kind to get any help would be great.
Compressor:
Puma LA5706 1-HP 1.5-Gallon Direct Drive Hot-Dog Air Compressor
I want to mount it in my tool box to have onboard air.
2001 F250 CCLB, PHP Hydra, 6637, MBRP 4" exhaust and rear air bags
97' F250 ECLB, 7.3, Baby Swamps, Hydra w/swamps tunes, 6637, 3"dp 4" straight, Dana 60, 2.25 PMF RSK, Built Trans & Cooler, DIY efuel
duxpsd is offline
post #2 of 3 (permalink) Old 06-19-2016, 02:54 AM
Administrator
Zmann's Avatar
Re: Air compressor install questions
the site does not list the AMP draw so ??
typically these don't do well with inverters it's better to get a 12v motor IMO
you figure 1HP may be around 16 amps and would need a inverter over 1000 watts that needs a big cable but you can mount close to the batteries then run the compressor cord to the inverter
it's far from ideal even for free
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #3 of 3 (permalink) Old 06-27-2016, 07:39 AM
Terminator Nation
What do you want to use the air for? That size compressor is not going to let you use air tools of any size.
old man dave is offline
