brake,reverse,turn lightbar how too. - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 05-06-2016, 03:33 PM Thread Starter
i bought a tailgate light bar (fits between the bumper and tailgate) with brake, revers,e turn signals. come with the 4 pin trailer connector. a white white for the power reverse and a red power wire off the battery. my only question is do i need to run a wire to the front of the vehicle off the battery or can i get it some where off the back?
RI-7.3 is offline
post #2 of 5 (permalink) Old 05-06-2016, 09:40 PM
Optimator82's Avatar
Re: brake,reverse,turn lightbar how too.
What function does the red wire feed power to on your light bar? Does it have something like auxiliary work lights incorporated into it?
Joe
96 F-250 ECLB w/7.3, E4OD, Dana 60, 6637, KC TP38r, Hydra w/PHP tunes, Swamps HV/HF IDM, Efuel, HB Sr. HPOP, 3"dp to 4"exhaust with aero turbine muffler, Riff Raff bellowed up pipes, gauges - aeroforce interceptor, isspro ev2 pyro, boost & trans temp, IH water pump, Horton Efan clutch, hydroboost, 230amp alternator.
Optimator82 is offline
post #3 of 5 (permalink) Old 05-06-2016, 09:42 PM Thread Starter
its says constant power full time 12 volts.
RI-7.3 is offline
post #4 of 5 (permalink) Old 05-07-2016, 04:35 AM
Huh. Not sure why it would require a separate power source when the power for your turn, stop, and reverse lights would be obtained by tapping into your existing circuit for those wires via the 4 way trailer plug. Have you tried just hooking it up using the 4 way trailer plug and tapping the white wire into your reverse lights to see how it functions without supplying power to the red wire?
Joe
post #5 of 5 (permalink) Old 05-07-2016, 05:22 PM Thread Starter
No I haven't. I'll try it soon though.
RI-7.3 is offline
