2002 f350 7.3 2wd lift/stacking - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 02-14-2016, 11:52 AM Thread Starter
Long time lurker and first post here. I have searched all over the forum but cant find what im looking for specifically so figured i would ask the pros here. With a 2wd, options are limited for a 6" lift so i most likely im going with Fabtech 6" but still want a couple more inches. Just enough to put a set of 37s under...so maybe 6" and 2" spacers? Is alignment possible? This truck is strictly for fun, it wont see off road, hauling 5th wheels, etc. I just like the stance of a taller truck. Thx
Sent from my SAMSUNG-SM-N920A using Tapatalk
shannon.lawrence is offline
post #2 of 4 (permalink) Old 02-17-2016, 06:27 PM Thread Starter
Re: 2002 f350 7.3 2wd lift/stacking
Nobody?
post #3 of 4 (permalink) Old 02-23-2016, 09:30 PM
AK1
AK1's Avatar
Garage
Not sure on the front of a 2X, rear is easy. If it's got the split axle like the older Ford 2X's you'll need to drop the center the same amount. Couldn't even find an image of a 2X front axle in a quick search.
Maybe check the suspension section of the forum
'00 Excursion Limited w/170k (rebuilt), 4X, V/B codes, 35" Toyo, 4" intake/exhaust, WW, TW, Isspro, FF Stage 1, T500- mix of '00/'05/'08/'12/'14 parts
SOLD: '00 F350 CC, '95 F350 CC, 2X '83 F250 6.9's.
AK1 is offline
post #4 of 4 (permalink) Old 02-24-2016, 05:25 PM
I once had the 4.5 Edge hanger lift on a 2002 F350 and purchased their mini spring pack kit. Remove one spring from the pack for an addition 1.5 inched in the front to make a total of 6 inches. I had no issues at all with this setup. I'm not sure on details regarding a 2002 F250 when compared with a 2002 F350 however other than the higher block in the back.
gooseman80 is offline
