Air Tanks and train horns??? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 19 (permalink) Old 12-27-2007, 10:01 PM Thread Starter
<<< THE GAUGE WHORE...
CSIPSD's Avatar
Just ordered my kit today. I have a 5 gallon tank coming with the kit, and will be adding two more 3 gallon tanks from a mixer. My plan is to mount all three tanks where the spare used to rest, then the pump in the tool box next to the water tank. Anyone have any feed back? Thinking I will add two air QC at each side of the tool box, drivers and passangers...
Joe
CSIPSD is offline
post #2 of 19 (permalink) Old 12-27-2007, 11:25 PM
gregrob's Avatar
Re: Air Tanks and train horns???
I would do something to protect the tanks from Off-Roading / Snow / Mud damage. Otherwise sounds pimp.
Get us pics, and sound clips
gregrob is offline
post #3 of 19 (permalink) Old 12-27-2007, 11:32 PM Thread Starter
CSIPSD's Avatar
I am thinking some 1/8" sheet to line the bottom, then the drain valves will be the only thing hanging, but there WAY up there!!!
Joe
CSIPSD is offline
post #4 of 19 (permalink) Old 12-27-2007, 11:33 PM
gregrob's Avatar
Cool. How are you going to attach it to the truck? Span the frame rails, or drill holes in the spare tire bracket, or?
gregrob is offline
post #5 of 19 (permalink) Old 12-27-2007, 11:35 PM
South Atlanta white trash
Doodie's Avatar
Sounds loud
Garmon's Diesel Performance
SOLD...
01' F250 CC 7.3
16.5:1, Mahle's .0050 with harden forged, 37 deg. valve job, Comp 910's, 4130 pushrods, Mac/K&N
H-11 studs, HT turbo, DP tuned, Bean's injectors/plentums, DI's fuel system
Built trans with Red Altos/PI triple disc.
2010 CC 6.4, 6" lift, 20's & 35's
Doodie is offline
post #6 of 19 (permalink) Old 12-27-2007, 11:39 PM
DILLIGAFF
Send a message via AIM to Redfish
Yeah I plan to put my pump and 5 gallon tank in the bed, next to my tool box, so I can run a nail gun etc. if I need to. The horns.... well there only one place they could go..... and thats where the T-case "should" be.
2006 F-250 CC King Ranch, Harley Headlights w/ 55w HIDs
ARP studs, MBRP 4" exhaust and AM Colbalts By:
, AFE stg. 2 Pro Guard 7 from XDP, SCT from innovative!
14.09 @ 94 1.85 60'
Redfish is offline
post #7 of 19 (permalink) Old 12-28-2007, 01:34 AM
I love you bigrpowr!
QtrHorse's Avatar
I have no idea how to find it but there was a post over on TDS where someone mounted his tanks in the exact same spot. He also had a somewhat hidden quick connect in or under the back bumper. He had a custom bracket and I believe skid type plate made up. It was a nice install.
99.5 F250 XLT S/C 6SPD
I have no ring and no love from the mods.
QtrHorse is offline
post #8 of 19 (permalink) Old 12-28-2007, 02:41 PM Thread Starter
CSIPSD's Avatar
I was thinking about modding the spare jack and making it lowerable... but those things are prone to breaking anyway so I most likey will build a frame that spans the rails...
Joe
CSIPSD is offline
post #9 of 19 (permalink) Old 12-28-2007, 02:51 PM
Sleep well my brothers
yamt03's Avatar
with that many tanks you might want to upgrade your pump to a 100&#37; duty cycle or run an extra pump.
Early 99 CC DRW AFE, 4" MBRP,Autometer,6.0 trans cooler, ITP, DP Tuner and cupholder upgrade
Former U.S.A. Res. MP & proud of it!
2005 Dodge 4x4 5.9 With some stuff done to it.
"If you voted for Obama in 2008 to prove you're not a racist…you'll have to vote for someone else in 2012 to prove you're not an idiot."
yamt03 is offline
post #10 of 19 (permalink) Old 12-29-2007, 01:35 AM
Banned
What size compressor are you using because I have 2 viair 480C's for 1 8 gallon tank and you are going to use 1 comp for 11 gallons it is going to take forever to fill up and recover and what psi do you plan on running.
GOT FUEL is offline
