Coolant filtration system - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 02-07-2016, 01:33 AM Thread Starter
Davesyd's Avatar
What do oh guys think of a coolant filter, I'm kinda new with diesels and I'm not sure what it actually helps, I know it filters the coolant, can it help prevent my head gasket growing
Davesyd is offline
post #2 of 5 (permalink) Old 02-08-2016, 05:15 PM
DIESEL DAN's Avatar
Re: Coolant filtration system
I have one and love it! Made my own kit, it more less saves ur water pump from going bad due to the sand casting inside block.
Early 99'(10/18/98)f-250,4x2,Super Cab XLT 8' Bed
MBRP 4" Turbo Back
Swamp's Diesel IDM
Grover 1700 Single Trombone Air Horn
Coolant filter Bypass W/ Napa Gold #4070 Filter
Air Intake W/CCV Mod,V-10 Trans Cooler
Stewart Warner Gauges: Trans,Pyro,Boost,
20% Window Tint
Retro Solutions 55 watt HID's 5000k
08' Super Duty Finned Diff Cover
DIESEL DAN is offline
post #3 of 5 (permalink) Old 02-08-2016, 06:03 PM
EA - Eggfarts Anonymous!
Turd-250's Avatar
plus it serves as an excellent monitor for how clean the coolant system is!
"Farts are like a good bourbon, add a small touch of water to bring out the excellence."
Turd-250 is offline
post #4 of 5 (permalink) Old 02-08-2016, 06:32 PM
Moderator
Sbluke55's Avatar
7.3 not required but helpful
6.0 and 6.4 pretty much required
6.7 I'm not sure.
01 f-250, Standard
Sbluke55 is offline
post #5 of 5 (permalink) Old 02-09-2016, 10:43 PM
Terminator Nation
Guys who had 100k on their7.3 trucks with regular coolant service reported getting casting sand in the filters after installing a coolant filter.
I think the cleanest way to install a coolant filter is to change out the water pump for one that has the integral filter. Both IH and DieselSite have them for the 7.3. You do have to change out the oring for the filter shutoff valve.
http://www.dieselsite.com/forddieselwaterpumps.aspx
old man dave is offline
