Wiper blades - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 02-05-2016, 04:36 PM Thread Starter
Luddite in Charge
Mr_Andy's Avatar
Wiper blades
OEM and all the 'books' call for 20" wiper blades on these trucks. Looking and measuring tho, there's no reason a 22" wouldn't fit. Anyone go with larger-than-OEM and if so, issues?
Mr_Andy is offline
post #2 of 11 (permalink) Old 02-05-2016, 05:25 PM
EA - Eggfarts Anonymous!
Turd-250's Avatar
Re: Wiper blades
in the past i've used oversized wipers on windshields with a slight enough curve over to the far passenger side that it would loose contact in wet freezing weather & let ice buildup/creeping towards the center of the glass... not too big a deal. second, on my ranger, installing an oversized blade requires bending the radio antenna over a bit, still not a big deal, just sayin lol
"Farts are like a good bourbon, add a small touch of water to bring out the excellence."
my farts are so bad, they have been banned in 37 countries!
Turd-250 is offline
post #3 of 11 (permalink) Old 02-05-2016, 07:01 PM Thread Starter
Luddite in Charge
Mr_Andy's Avatar
Re: Wiper blades
I'm looking at the resting position of the blade as well as it's arc of travel, and don't see anything that would come close to interfering with an extra 1" on each end of the blades. I'll just make sure to save the receipt in case something does
Mr_Andy is offline
post #4 of 11 (permalink) Old 02-05-2016, 07:44 PM
Turd-250's Avatar
Re: Wiper blades
hell i may grab some 22" next time i change them!
Turd-250 is offline
post #5 of 11 (permalink) Old 02-05-2016, 10:15 PM Thread Starter
Luddite in Charge
Mr_Andy's Avatar
Re: Wiper blades
I wonder if the 'perma-grit' that's on the un-wiped part of the windshield would have a negative effect on the whole works....?
Mr_Andy is offline
post #6 of 11 (permalink) Old 02-06-2016, 01:50 PM
Turd-250's Avatar
Re: Wiper blades
only if ice starts to gather on the grit while on route maybe... if it did, it might 'lift' the blade enough to stop it from really cleaning off the edge of the normal wiping area? no harm in testing it tho! perfect time of year lol
Turd-250 is offline
post #7 of 11 (permalink) Old 02-06-2016, 05:41 PM Thread Starter
Luddite in Charge
Mr_Andy's Avatar
Re: Wiper blades
I'm rapidly seeing irrefutable reasoning why the middle of winter is not the wisest time to test these things. Naturally I will anyway.
Mr_Andy is offline
post #8 of 11 (permalink) Old 02-06-2016, 06:16 PM
Turd-250's Avatar
Re: Wiper blades
i'm thinking about washing my truck tomorrow before the PooperBowl, i'm now inclined to investigate just how much different the surface is between the wiped & un-wiped area... 235k highway miles worth of pitting on the stock windshield & you can tell!
Turd-250 is offline
post #9 of 11 (permalink) Old 02-06-2016, 06:46 PM
ptanner3's Avatar
Re: Wiper blades
I've used 22s for a while with the thought, bigger is better. No issues, no noticeable positives either.
'02 f-250 cc srw 4x4, auto
'08 f-350 CC dwr 4x4 auto
ptanner3 is offline
post #10 of 11 (permalink) Old 02-06-2016, 07:15 PM Thread Starter
Luddite in Charge
Mr_Andy's Avatar
Re: Wiper blades
There we'll have it. I was mostly worried with 2" more of a span for the ribs to keep tight, was there any issue with missed spots against the glass
Mr_Andy is offline
