2002 F350 on to a 2008 rolling chassis? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 02-01-2016, 04:18 PM Thread Starter
Gulfcoast's Avatar
I am looking to swap to coil suspension on my 02. I can get a full rolling chassis including the steering gear and linkage in place for a couple hundred bucks more than just the axles. First question: is this worth doing or is it just going to make things more complicated compared to swapping the axles, spring buckets, etc.? Second question is if it is doable is the frame from a extended cab long bed the same as a crew cab short bed?
2013 F250 Platinum 4x4 CC 6.7- Carli Commuter 2.0 suspension, 18x9 BMF Novakane, 35 12.5 R18 Nitto Trail Grappler MT, Titan 50 gallon fuel tank
2002 F350 XLT 4x4 Crew Cab 7.3L
Gulfcoast is offline
post #2 of 4 (permalink) Old 02-01-2016, 05:57 PM
Moderator
Sbluke55's Avatar
Re: 2002 F350 on to a 2008 rolling chassis?
I'm pretty sure the frames are different from a extended cab and a crew cab. I could be wrong though.
If you do frame swap you would have to swap the front sheet metal to a 08-10 because the front of the frame is different.
But upgrading to some 08+ rear springs will help with the ride some. You also will need the 08 steering box or ream out your stock pitman arm.
01 f-250, Standard
Sbluke55 is offline
post #3 of 4 (permalink) Old 02-01-2016, 11:58 PM
Strokin all day
Spence's Avatar
The frames are definitely different. Extended cab long beds are also longer than cc short
08 F350 Spartan tuned, egr delete, 5 in turbo back, no limit cai, ccv, cac pipe, bd 6.0 manifolds, bd up pipes, coolant filter.
3 vehicles in the scrap yard.
1 cummins sold to some boner next town over.
Spence is offline
post #4 of 4 (permalink) Old 02-02-2016, 03:25 PM Thread Starter
Gulfcoast's Avatar
Thanks for the info
