2005 header panel on 1999? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 01-19-2016, 08:19 PM Thread Starter
#78f350's Avatar
Hi guys,
Im in the process of converting to the 2005 front. I have the grill and headlights, just need the bumper.
My question is, does the 2005 header panel bolt right up in my 1999? I would rather do that instead of cutting my header panel.
Also, do I need the 2005 bumper brackets too?
Thanks
1999 F350 7.3 4x4 MBRP 4in Turbo back and K&N Filter
1978 Ford F350 2wd Reg Cab. 400 with C6 trans, currently under restoration
#78f350 is offline
post #2 of 13 (permalink) Old 01-19-2016, 08:48 PM
Moderator
Sbluke55's Avatar
Re: 2005 header panel on 1999?
Header panel will bolt right up.
I don't know about the bumper brackets. I would guess you would.
01 f-250, Standard
Sbluke55 is offline
post #3 of 13 (permalink) Old 01-19-2016, 08:51 PM Thread Starter
#78f350's Avatar
Thanks, header panels are not that expensive new, so thats good.
#78f350 is offline
post #4 of 13 (permalink) Old 01-24-2016, 05:50 PM
I like Diesel.
WelchyBoy833's Avatar
I'm in the same boat as you, as far as swapping front ends. I'm making my own headlights, and have already installed the grill and bumper. I directly swapped the 05 bumper on I didn't mess with changing the mounted or anything, but I imagine it would work either way.
Sent from my Gigaset QV830 using Tapatalk
97 F-250HD Extended Cab Long Bed | 4x4 | 5 speed | 3" down pipe 4'' exhaust | K&N | Bigger turbo | New Injectors | 333,000 miles still running strong
WelchyBoy833 is offline
post #5 of 13 (permalink) Old 01-26-2016, 04:00 PM Thread Starter
#78f350's Avatar
I have my grill on, but need to still install the lights then find a bumper. At this point Ill just cut my header panel and put that money towards a bumper and paint.
#78f350 is offline
post #6 of 13 (permalink) Old 01-27-2016, 07:28 PM
Big dumb redneck
6speedSD's Avatar
Garage
Header panels can be bought new for $50-75. ,y buddy just did the swap on his 99...found a panel somewhere online for $55. It's worth that to not fool with cutting and all that mess.
2005 F350 CCLB Dually
Studded, deleted
5" straight piped
155/30's
KC Stage 1.5
Reg return
Beans sump to the stock pump
BPD FICM
6speedSD is offline
post #7 of 13 (permalink) Old 01-31-2016, 02:46 AM Thread Starter
#78f350's Avatar
Thats what Ive been told my buddies that have done the convertion. Ive heard its quicker to do the panel, is that true?
#78f350 is offline
post #8 of 13 (permalink) Old 01-31-2016, 03:00 AM
Big dumb redneck
6speedSD's Avatar
Garage
It has to be quicker than cutting/fitting. A header panel is less than 10 bolts I think...remove bolts, old off, new on, bolts back in. That way your newer style lights will just bolt right up to the new panel.
Basically just depends on your time available, if you like fooling with alterations vs just swapping parts, etc.
Studded, deleted
5" straight piped
155/30's
KC Stage 1.5
Reg return
BPD FICM
6speedSD is offline
post #9 of 13 (permalink) Old 01-31-2016, 11:16 AM
Moderator
Sbluke55's Avatar
You need the correct header panel or the bottom of the grill won't snap in. Because your doing the full conversion you need the header panel.
01 f-250, Standard
Sbluke55 is offline
post #10 of 13 (permalink) Old 02-01-2016, 12:05 AM
Yes, you need the bumper brackets as they are different from the 99-04 brackets. If I remember correctly, the outer "vertical" brackets are different as well. I had a set of the outer ones laying around, so I just used them, didn't compare them to the early style.
benny
Originally Posted by #78f350 View Post
Hi guys,
Thanks
gogo5.0 is offline
