Help! 1999 7.3L Fan upgrade........ - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 16 (permalink) Old 11-03-2015, 01:20 AM Thread Starter
gemini_nkr's Avatar
Hi guys, I am putting my 1999 F350 7.3L back together, I ordered the 6.0L intercooler and I want to run a lighter fan, I saw everyone with the old 7.3L running the 6.0L fan, but will it fit the 1999 an up?
Secondly, the 7.3L has a 9-Blade fan 10lbs, how many blades does the 6.0L fan have?
Lastly, anyone ever tried running any other lighter fans like those off an F150 or V10 F350? I see them using 11-Blade fans and I don't know if they have a cfm rating than that of the 9-Blade.
I tried going to my local fords parts store and these guys looked at me like I was talking greek, they couldn't even understand that I just wanted to cool my engine more efficiently even if I will lose a little of power. I don't plan on towing much.
Any help will be greatly appreciated!
gemini_nkr is offline
post #2 of 16 (permalink) Old 11-03-2015, 01:31 AM Thread Starter
gemini_nkr's Avatar
Re: Help! 1999 7.3L Fan upgrade........
Ok, so I finally saw a site listing an 11-blade fan for a 1999 F-250, will that flow more air than the 9-Blade.
Sorry for the many questions but I start reassembling the truck tomorrow and I don't have all the parts.
Finally, has anyone ever used the Aluminum blades? They say they are lighter and don't break unlike the plastic ones and have a better heat resistance.
post #3 of 16 (permalink) Old 11-24-2015, 06:50 AM
Terminator Nation
The aftermarket aluminum/steel ones have the same CFM problems as the fiberglass ones.
Is the listing for a 6.0 fan?
old man dave is offline
post #4 of 16 (permalink) Old 12-25-2015, 05:02 PM
what is the "CFM problem"
djs96 is offline
post #5 of 16 (permalink) Old 12-26-2015, 03:53 AM
Terminator Nation
The aftermarket fans do not pull as much air (cubic feet per minute) across the radiator as the plain old stock 7.3 fan. This makes it difficult for those who want to eliminate the stocker to find a suitable replacement, either fiberglass, aluminum, steel or electric.
post #6 of 16 (permalink) Old 12-28-2015, 04:00 PM
Big dumb redneck
6speedSD's Avatar
Garage
How much "lighter" are we talking here? I mean, if you are only looking at a pound difference, then what's the issue or the point?
The 6.0 fan is light by itself (i.e. No clutch), but as far as I know, the only clutches it'll bolt up to are the stock 6.0 one, and the 97 style clutch.
2005 F350 CCLB Dually
Studded, deleted
5" straight piped
155/30's
KC Stage 1.5
Reg return
Beans sump to the stock pump
BPD FICM
6speedSD is offline
post #7 of 16 (permalink) Old 10-13-2016, 04:41 AM Thread Starter
gemini_nkr's Avatar
Well, I eventually ended up going with an aluminum blade, it's a HUGE weight saving, I am yet to drive the truck outside my neighborhood, but I pray that it works great.
So far, I can let it idle for hours, rev it up and the temp stays low............
1999 F350 Superduty 7.3L TD
post #8 of 16 (permalink) Old 10-13-2016, 04:43 AM Thread Starter
gemini_nkr's Avatar
post #9 of 16 (permalink) Old 07-07-2017, 10:43 AM Thread Starter
gemini_nkr's Avatar
HELP PLEASE!!! I am stuck in Kentucky, I have a very heavy load and my truck is overheating after a few miles, the fan clutch has a lot of resistance when I spin it, I don't know if it is too much or if the fan is NOT pulling enough air.
I used a 6-Blade aluminum fan that saved me TONS of weight but under heavy load, the temperature goes up.
Could it be the fan clutch is bad or the aluminum fan is NOT sufficient?
I have seen videos showing the fan engaged, the sound is LOUD, I have NEVER heard that sound before, also, the aluminum fan has a smaller radius than the factory fan.
What do you guys think?
post #10 of 16 (permalink) Old 07-07-2017, 02:23 PM
Native Texan
masakimm's Avatar
Garage
Man i just finished a water pump on a 7.3l and that fan is tiny theres no way it could move enough air to cool a 7.3l that fan look like it was made for a small gas motor.
Sent from my Super awesome outdated Samsung that doesn't burst into flames using Tapatalk
Upgrades:
masakimm is offline
