converting f250 to a dually? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 09-06-2009, 12:25 AM Thread Starter
Is it hard, cost a lot? I'm looking for one but if I can't find a dually for the right price and I find an f250 for a nice deal I may pick it up and later on convert to a dually.
pimpedout97x is offline
post #2 of 12 (permalink) Old 09-06-2009, 12:33 AM
Re: converting f250 to a dually?
dually axles and a dually bed........ anybody else think something needs to be added?
02 f250
countryboyrob is offline
post #3 of 12 (permalink) Old 09-06-2009, 01:25 AM
Don't EFN worry about it
Aljay's Avatar
Wiring for the dually fender lights
Tuned by T Wildman
Aljay is offline
post #4 of 12 (permalink) Old 09-06-2009, 01:42 AM
02 f250
post #5 of 12 (permalink) Old 09-06-2009, 03:49 AM
tbolt's Avatar
Most dually's have 4.10's and most srw's have 3.73's. I think the spring perches need to move but not sure about that. A 250 long bed may be hard to find. These are just guesses, I have never done it but thinking about converting my 350 lb srw.
Glen
early99 f350 cc, lb, 2wd, drw, A pillar autometer guages, CTS monitor, AIS intake, 4" turbo back cat delete diamondeye exhaust, dptuner, pmt1, jw vb, Swamps ab inj, Adrenaline oil, Coolingmist, 180*T, Trucool cooler, spin on trans filter, Firestone air bags, 2" frt leveling kit, now chased by a 34' toyhauler
tbolt is offline
post #6 of 12 (permalink) Old 09-06-2009, 04:47 AM
Send a message via AIM to JohnT
I believe you don't need a dually box considering the duallies have a sort of fender flare you can probably bolt on to a standard box. I am not 100% sure of it, but I know that the the dually fender is no molded to the box.
A dually axle is going to be expensive, everytime I see them they are quite expensive. If you are 4wd you will have to re-gear your front also, which is even more cash, since most duallys are 4.10 like tbolt said.
99 PSD 4x4 CCLB
05 PSD 4x2 RCLB
JohnT is offline
post #7 of 12 (permalink) Old 09-06-2009, 05:39 AM
tbolt's Avatar
There is a co called Arrowcraft that makes adaptors for this. They have complete pkg with fenders and everything. Uses your stock axle.
Glen
tbolt is offline
post #8 of 12 (permalink) Old 09-06-2009, 11:17 PM Thread Starter
i think ill just stick with the dually from the get go haha
now, converting a dually 2wd to 4x4? say i have a parts excursion that is 4x4? will the parts work even though the 350 is a dually?
post #9 of 12 (permalink) Old 09-06-2009, 11:44 PM
peterbilt'in
Rob02F350's Avatar
i was thinking about the same thing...
do you really need the axles... or hubs?
full floats, the axle bolts to the hub... bolts to the wheel's... unless the axles have to be longer or something?
2002 F350 extended cab XLT, 4x4 auto,194K mi @ 10/25/13, ELF7405, DP F5, ultra light gauges, all kinds of "improvements" Yukon Grizzly locker 6K helper springs, x code fronts. 2 Y2K jetta Tdi. RC2 tuned
Rob02F350 is offline
post #10 of 12 (permalink) Old 09-07-2009, 05:49 AM
Custom Trailer Sales
TrailerHauler's Avatar
If its a manual T-case it will be easier. If they're the same tranny, swap in the one with the transfer case, or swap the rear housing and transfer case onto the tranny. Bolt up the hangers and the axle. You'll need different hubs and gears for it to be a proper swap.
1999.5 F350 PSD CC Dually 05' Conversion
Stage I's - Gearhead Tuning - BTS - PCS
F550 rear suspension
1999.5 F350 PSD S/C 6spd Dually
R.I.P. Will Iott - "This ain't no practice run"
TrailerHauler is offline
