Need help asap....front end - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 09-01-2009, 11:44 PM Thread Starter
Joedog's Avatar
Hey guys..... i started to get a squealing noise from the front end about a week ago... i assumed it was brakes and would fix it soon. Well today it got bad quick. Started with a rubbing noise and a squishing noise then it would pull hard to one side and was hard to steer.
When i barely made it home i took the truck and jacked it up on the drivers side where the noise was. I placed my hands at 12 and 6 and went to push and pull. There was a ton of movement.....it seems the ball joints are not moving, but there is a lot of movement at the u joint and behind it.....
I need to know if it is the u-joints or the hub assembly...it was very hot when i took off the wheel to inspect. And the caliper is nearly locked up pushing the pad into the rotor.....help this is my only transportation.
2000 F-250 Supercab/Shortbed 6-speed
Swamp Ass Hybrids, Swamp Ass tuning, Stage 1 Oil, 38R, Southbend Clutch.
Joedog is offline
post #2 of 5 (permalink) Old 09-01-2009, 11:49 PM Thread Starter
Joedog's Avatar
Re: Need help asap....front end
alot like this
Joedog is offline
post #3 of 5 (permalink) Old 09-01-2009, 11:56 PM
Starting Over
kainers's Avatar
It is wheel bearing.Once it goes the wheel starts riding on the caliper.The faster you go the less is grinds<LMFAO that is a joke not serious DON'T DO IT even though I did.
Quick fix go buy one.They are about 350 bucks.Use to come with lifetime warranty.All your major part stores will have them in stock.Easy as hell to replace like under a hour.
kainers is offline
post #4 of 5 (permalink) Old 09-01-2009, 11:57 PM
Starting Over
kainers's Avatar
Another thing is spin the wheel off the ground you should hear it grinding at this point.
kainers is offline
post #5 of 5 (permalink) Old 09-02-2009, 12:02 AM
original "REZNECK"
kbnord's Avatar
you can get them cheaper from a non ford dealer (napa) if you can get by with out the rig ebay had them for 150 at one time with a lifetime warranty. which ever option you take, remove the caliper slide bolts and reinstall them with locktite.
twice tottalled
01 F250 cc 4x4 straight pipe, custom front and rear bumpers, 1 ton rear susp, flatbed, TS Chip, king ranch rims, 315 tires
Originally Posted by Aljay
Since when do 7.3's puke coolant like an overfilled hooker on a busy night ?
kbnord is offline
