gauge installing tips - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 25 (permalink) Old 08-16-2009, 12:31 AM Thread Starter
it's an 02 05 08
turbodiesel_02's Avatar
I just ordered an isspro pyro and boost gauge setup for my 02 and was wondering if there are any tricks or tips to putting them in.i have never installed gauges before,thanks
2002 ext. cab lwb 4x4 7.3
05 front 08 rear conversion
4in lift,forged rod motor,tunes by tsd,bts trans,6.0 transcooler,6 autometers to watch,studs,springs,push rods,238cc hybrids,itp reg return,stealth hpop,tsd custom fuel system and sump,an so on
6.0's pay the bills and 6.4's soon..
turbodiesel_02 is offline
post #2 of 25 (permalink) Old 08-16-2009, 12:55 AM
Super Hauler!
Super_Hauler's Avatar
Re: gauge installing tips
you just got one gauge? Put the pyro in the drivers side manifold before uppipe.
Super_Hauler is offline
post #3 of 25 (permalink) Old 08-16-2009, 12:58 AM Thread Starter
it's an 02 05 08
meant pyro and boost
post #4 of 25 (permalink) Old 08-16-2009, 01:26 AM
Everybody poops <~ see?
dennisr_f350's Avatar
Send a message via MSN to dennisr_f350
Easy breazy, bud. Just keep the drill bit well coated in vasolene, to catch the pieces of manifold. The boost guage should just be a simple T fitting.
What did you get to display them in? An A pillar pod?
2007
F350 SuperDuty
Some air
Some fuel
Some grip
Some guages
The usual suspects.
dennisr_f350 is offline
post #5 of 25 (permalink) Old 08-16-2009, 01:36 AM Thread Starter
it's an 02 05 08
i got an a pillar pod,will keep the vasolene trick in mind,i was sort of under the impression that you had to pull the manifold to keep the shavings out,but is all new to me
post #6 of 25 (permalink) Old 08-16-2009, 01:38 AM
take your time. when drilling into the manifold do it in steps, like start off with a smaller bit then whats required for the probe.
02 f250
countryboyrob is offline
post #7 of 25 (permalink) Old 08-16-2009, 02:12 AM
matthewd11's Avatar
Shavings wont really matter. It'll just go right out the exhaust.
matthewd11 is offline
post #8 of 25 (permalink) Old 08-16-2009, 02:15 AM
black_pstroke's Avatar
Originally Posted by dennisr_f350 View Post
Easy breazy, bud. Just keep the drill bit well coated in vasolene, to catch the pieces of manifold. The boost guage should just be a simple T fitting. What did you get to display them in? An A pillar pod?
you can also drill/tap your intake elbow and run it from there
black_pstroke is offline
post #9 of 25 (permalink) Old 08-16-2009, 02:42 AM
i would do it this way unless you have aih plug with a fitting on it ive install a couple of those crappy t fittings they give you with the boost guage and had a couple of the lines blow out
99.5 F-250 X-CAB SHORTBED 4X4
Dyno proven tuning
suncoast tranny
P.I.S 238CC/200% hybrids
irate s471 turbo
Fuel system
stealth srp1 hpop
arp studs
comp 910s
CUMMINS_KILLA99 is offline
post #10 of 25 (permalink) Old 08-16-2009, 01:06 PM
Lovin Life...
02BigD's Avatar
Would metal shavings moving at high velocity agree with the turbo?
02-350. CCSB - Drivetrain by Stauffer, fuel by Swamps, air by Barder, tunes by Gearhead.
04-250. ECSB - In the shop...7.3 swap.
02BigD is offline
