Confused I Need Help! - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 08-15-2009, 01:51 AM Thread Starter
d-man
99coalroller's Avatar
Ok so i have been looking at Xd wheels and am trying to figure out what backspacing and offset i need to buy in order to get the wheel and tire to stick out about 2 inches from the fender so that they look right under my pocket flares. I would like the Xd 441 series and they only come in a -6mm offset with a 5.24 offset. I will be running toyo 35x12.50x18.
I have been reading about offset and backspacing for the last hour and still can not seem to be able to figure out if these wheels will work on my early 99 and stick out like i need them to. Any help would be greatly appreciated as i am very confused at the moment.
Thanks guys
2005 F350 CCLB King Ranch, 2.5"' Level, 35" Toyos on 08 20's, EGR Delete, 5" MBRP, Blue Spring, 6.4 Banjos, Rotella ELC
99coalroller is offline
post #2 of 6 (permalink) Old 08-15-2009, 02:21 AM
recon250's Avatar
Re: Confused I Need Help!
you need something with a 4.5" back space. a 10 inch wide wheel with a 4.5 bs will put it right to the fender
02 f-250 xlt with leather, BTS trans. dp-tunes, afe. 40" bfg km2 on some 20's. and a bunch of other stuff that doesent make it any faster.
recon250 is offline
post #3 of 6 (permalink) Old 08-15-2009, 02:32 AM
Attention Whore
UNBROKEN's Avatar
A 10" wheel with 4.5" backspace will stick out a bit. My 9.5" wide wheels with 5.95" backspace are just inside the fender.
+10 and +25 are very common offsets...the +25 will stick out.
If you're reading it in inches the less backspace the more it will stick out.
Spending money I don't have on crap I don't need to impress people I don't know.
UNBROKEN is offline
post #4 of 6 (permalink) Old 08-15-2009, 02:05 PM
Evil Genius
DCSpecial's Avatar
10" wides with 4.5" or 3.81" Back Space are going to be the closest to the fender flares.
DCSpecial is offline
post #5 of 6 (permalink) Old 08-15-2009, 02:59 PM
These rear wheels are 20x10's w/ 4.5" backspacing.. Tires are 305/50/20..
william_04_x is offline
post #6 of 6 (permalink) Old 08-17-2009, 02:24 AM
recon250's Avatar
[QUOTE=UNBROKEN;600904]A 10" wheel with 4.5" backspace will stick out a bit. My 9.5" wide wheels with 5.95" backspace are just inside the fender.
QUOTE]
the more postive the offset in mm the more it will stick in, not out
recon250 is offline
