Fuel system - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 08-14-2009, 12:38 AM Thread Starter
I Wanna Go Fast
White Sled's Avatar
Fuel system
Can you say high flow fuel system
White Sled is offline
post #2 of 13 (permalink) Old 08-14-2009, 02:34 AM
Village Idiot
southmike's Avatar
Re: Fuel system
All depends on the pump and line size....
southmike is offline
post #3 of 13 (permalink) Old 08-14-2009, 02:38 AM
PSDfan99's Avatar
Re: Fuel system
Highly filtered fuel system?
Early 99 F-350
4" lift on 33's. Daily Driver/ Plow truck.
Swamp's Gen3, 300/200's, Tuning, 76mm Sledgehammer. BTS. Fuel system, ARP's, P-Rods, 910's, and a few other things. Stock Block.
SOLD
New truck:
2009 F-350, 5.4L, 4" lift on 35's
PSDfan99 is offline
post #4 of 13 (permalink) Old 08-14-2009, 04:10 AM
Don't EFN worry about it
Aljay's Avatar
Re: Fuel system
Yep cat filters are da bomb. I am going to add one of those to mine some day don't know where but I need post pump filters.
Tuned by T Wildman
Aljay is offline
post #5 of 13 (permalink) Old 08-14-2009, 04:14 AM
What else?
smokyred's Avatar
Re: Fuel system
Nice, I run a Fleetguard FS1000 pre-pump and the Cat 1R-0749 post-pump.
Dave
smokyred is offline
post #6 of 13 (permalink) Old 08-14-2009, 04:16 AM
Keyboard Thug
Big Bore's Avatar
Re: Fuel system
I'm still trying to decide what filter to run post pump when I delete the bowl. Are CAT filters hard to come by?
99 F250 4x4 SC SB Eats 6.0's
Originally Posted by !!!PainTrain!!! View Post
I'm not saying the 7.3 is god's gift to diesel either. But atleast when a CPS goes out you can change it on the side of the road. I don't know about you but I'm running out of places in my glove box to store injectors, head studs, new heads, up pipes, fuel pumps, ficms, and a lift to remove the cab.
Big Bore is offline
post #7 of 13 (permalink) Old 08-14-2009, 04:17 AM
Aljay's Avatar
Re: Fuel system
Prepumps is a racor 10 micron filter/water seperator.
Tuned by T Wildman
Aljay is offline
post #8 of 13 (permalink) Old 08-14-2009, 04:24 AM
What else?
smokyred's Avatar
Re: Fuel system
No they are not, and places like NAPA can cross them to a filter of their's if you're stuck somewhere.
Dave
smokyred is offline
post #9 of 13 (permalink) Old 08-14-2009, 05:04 AM Thread Starter
I Wanna Go Fast
White Sled's Avatar
Re: Fuel system
Right this is going to be a highly filtered system with a 7 micron cat filter pre pump and a 2 micron post pump. It is not so important on the 7.3 power-stroke to run such high filtration as compared to the common rail systems for you 6.4 guys. but there are very close tolerances with in the injectors and this will help preserve the life of them. And you are right about the line sizing to make it a high flow fuel system. Cat filters are easy to pick up at your local cat dealer or cat parts supplier. the thing is that these filters are expensive (Cant Afford That). but the factory fuel filter along with the napa gold filter has a 19 micron filter. the cat filter is the only filter that I know of that has an absolute micron rating. meaning that when it says it filters the fuel down to 2 microns it actually does 100% of the time.
post #10 of 13 (permalink) Old 08-14-2009, 03:32 PM
Village Idiot
southmike's Avatar
Re: Fuel system
no injector likes anything bigger then 2 micron .
