Aftermarket lockout hubs - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 11-30-2007, 10:00 PM Thread Starter
IH_deere_slayer's Avatar
Got a 2000 Ford F-350 DRW cant find aftermarket lockout hubs for the 4X4. Checked with about every hub company known to mankind, cant get any for drw because of the extensions required for the front wheels. I really dont want to go with factory hubs. They are stuck locked and i broke the plastic part trying to turn it. I do have esof 4X4 but a manual locking hub would suit me fine. Anyone have any ideas???
2011 3500 HD Duramax
2006 T800 KW Daycab ISX Cummins
IH_deere_slayer is offline
post #2 of 10 (permalink) Old 11-30-2007, 10:12 PM
Hated by All
Fast_Ashley's Avatar
Re: Aftermarket lockout hubs
Get single wheel hubs from Warn for an '03.
You'll just have to reach your hand a little further in, a spacer is the only thing different on the duallys, but other than that your good......
PARIAH
2001 F-350
Resurection has begun.....
Fast_Ashley is offline
post #3 of 10 (permalink) Old 12-01-2007, 04:11 AM
OBS junkie
Cat_Rebel's Avatar
Can you conver your ESOF Transfercase to manual then or do you need a new case to do that?
97 F350 CCLB "Da Bus"
RIP Will Iott
"This ain't no practice run"
Cat_Rebel is offline
post #4 of 10 (permalink) Old 12-01-2007, 01:11 PM
Hated by All
Gotta' have the other case.....
PARIAH
2001 F-350
post #5 of 10 (permalink) Old 12-01-2007, 02:24 PM
OBS junkie
Cat_Rebel's Avatar
Thanks Ashley, good info to know.
RIP Will Iott
post #6 of 10 (permalink) Old 12-01-2007, 05:34 PM
Hated by All
No worries, I've been working on sh!t-canning my ESOF case in favor for the manual shift........
PARIAH
2001 F-350
post #7 of 10 (permalink) Old 12-01-2007, 08:34 PM Thread Starter
so your telling me i have to get a different transfer case if i get manual only locking hubs?
post #8 of 10 (permalink) Old 12-01-2007, 08:46 PM
Subject Matter Expert
PowerstrokeJunkie's Avatar
No, you don't.
Cut the vacuum lines that go to the steering knuckles, leave enough to insert a small bolt in the hose. Then hose clamp the bolt in to prevent a leak. Then, remove the stock hub lockers, install the new ones. I have Warn Premiums on mine, part 38826. There is always a good deal on them from Ebay so it seems, where i got mine. The hubs work as normal, the knob on the dash only controls the transfercase actions, however it also applies vacuum to the hubs to lock them. If you got it capped off the solenoid won't know a difference.
Here are mine..
Stock
PowerstrokeJunkie is offline
post #9 of 10 (permalink) Old 12-03-2007, 04:04 AM
rebelchevy02's Avatar
What does a set of OEM replacements cost anyways? Figure your OEMs lasted 7 years...... Thats gotta be worth something, and aside from when they finally freeze up, they dont break often, unless you do alot of pulling at the track..... Just my .02
DRW and tow fast parts.......
rebelchevy02 is offline
post #10 of 10 (permalink) Old 12-03-2007, 11:03 PM
Oooo, White Lightning !
Dieselboy's Avatar
Originally Posted by PowerstrokeJunkie View Post
No, you don't.
Here are mine..
I like the rims....Waht are they ?
Race truck
2002 F-350XL RC/LB
NADP Race Trans/PCS'd
Lowered w/ traction bars
Unlimited 450/400s
S475 on Irates mount
TE 17* with Gen3
DI Headers
Dieselboy fuel system
[email protected]
599.3 on BDs dyno
Tow pig
2000 F-250XLT EC/SB
Tuned
Exhaust
Intake
Dieselboy is offline
