New Rim Spacing Problem - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 07-26-2009, 03:46 AM Thread Starter
The Ontaribertan.
Sluther's Avatar
Hey guys,
Just bought some new rims and tires for the truck but I need some info on spacing. The new rims have a 5" backspacing and my stock rims are 4" so I am prepared to get spacers. However, if I get a 1" or 1.5" inch spacer, my studs will stick through and I will have to grind them down to make the new rims sit flush. But then what happens in the winter when I want to take the rims off and put the stocks back on for winter? Will there be enough thread left on the studs for my lugs to hodl enough? Does anyone know how far you can grind down before its too little stud left for the stock rims?
Thanks
SOLD -- 2000 F250 7.3 RegCab 4x4
2001 F250 SCSB 4x4 Lariat 120k -- 2.5" Levelled, Duelers on 20in Fuel Octanes, K&N Intake, MBRP 4", DP Tunes, AutoMeter Ultra-Lites.
1971 Chevelle 454 SS Clone -- Father/Son restoration
Sluther is offline
post #2 of 6 (permalink) Old 07-26-2009, 02:50 PM
Evil Genius
DCSpecial's Avatar
Re: New Rim Spacing Problem
You need a 2" spacer if you don't want to cut your studs.
What's the width of the new wheels and what size tires are you going to run?
DCSpecial is offline
post #3 of 6 (permalink) Old 07-26-2009, 04:23 PM
recon250's Avatar
i rand a few wheels with a 5" back space and never really had any problems. i was running 35's for a while and only problem was that it rubbed the fender every once and awhile
02 f-250 xlt with leather, BTS trans. dp-tunes, afe. 40" bfg km2 on some 20's. and a bunch of other stuff that doesent make it any faster.
recon250 is offline
post #4 of 6 (permalink) Old 07-26-2009, 06:34 PM Thread Starter
The Ontaribertan.
Sluther's Avatar
Im running 17x8 rims with 35". I was considering a 2" spacer, but I don't really want the tires to sit that far out passed my fenders, so I was going to go with a 1.5" spacer. But I'm guessing the only way to get around the problem is to go with a 2"?
Sluther is offline
post #5 of 6 (permalink) Old 07-26-2009, 06:37 PM
Stroker67's Avatar
Roll with a 2" spacer and put some badass bushwacker fender flares on her!
Stroker67 is offline
post #6 of 6 (permalink) Old 07-26-2009, 09:28 PM
BUFF's Avatar
Try the rims and tires on the truck first and then see if you even need spacers.
06 F350 CC LB 4x4 with a few odds and ends
BUFF is offline
