Wheel backspacing question - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 14 (permalink) Old 07-15-2009, 12:39 PM Thread Starter
Blackford's Avatar
I am looking to buy a set of aftermarket wheels for my '01 superduty and have a question about wheel backspacing. I am currently running 315/75/16 on factory 16" wheels which have a backspacing of 4.5", correct me if I'm wrong. At full turn the tires barely clear the leaf springs. If I go with an aftermarket wheel with a backspacing of 5" and the same size tire, there is a very good chance that the tires will rub the leaf springs. Am I correct on this or am I missing something? Does wheel width come into play anywhere?
Thanks
Blackford is offline
post #2 of 14 (permalink) Old 07-15-2009, 01:38 PM
Lovin the Tuna
RedSmokey's Avatar
Re: Wheel backspacing question
You are correct. 5" backspacing is pretty much for the newer trucks 05 and up with the coil springs. They dont have to worry about rubbing spring. Find a wheel with less backspacing as you are correct, if you are very close to rubbing now, taking that half inch in will likely make you rub.
2001 F250
2000 F250
RedSmokey is offline
post #3 of 14 (permalink) Old 07-15-2009, 01:57 PM
6Leaker
jdc753's Avatar
Send a message via AIM to jdc753
The newer trucks have wider axles and need more backspacing to keep the tires under the truck and not rub the bumper, or fender/inner fender.
Just need to pay attention to the Backspacing versus the width of the rim, as the rim gets wider you will want a little more backspacing to compensate for the added width.
BTW, to PSN, and looks like a pretty good truck ya got there
2005 F350 Crew Cab Long bed
6.0L / Auto 4x4
SCT X3 5" Magnaflow
4" RCD lift, a bunch of stereo gear and a computer
jdc753 is offline
post #4 of 14 (permalink) Old 07-15-2009, 05:34 PM
Evil Genius
DCSpecial's Avatar
Back Space is a constant over all wheel widths.....on a 99-04 you primarily stick with 4.5" Back Space.
You can do less and push the tires out more but it increases your scrub radius, wear and tire on the front end and can cause clearance issues with the bumper and fender.
Offset varies by width.....so you need to know both offset and width to know how well the wheel will work.
For example:
10" wide wheel with 4.5" Back Space is -25mm offset
12" wide wheel with 4.5" Back Space is -51mm offset.
DCSpecial is offline
post #5 of 14 (permalink) Old 07-15-2009, 06:49 PM Thread Starter
Blackford's Avatar
Thanks alot guys, I thought I was on the right track but just wanted to make sure.
post #6 of 14 (permalink) Old 08-06-2009, 01:16 AM
Would a 10" wide wheel with a 0 offset fit a 01 250?
clawson is offline
post #7 of 14 (permalink) Old 08-06-2009, 01:22 AM
Evil Genius
DCSpecial's Avatar
4x4?
If so, that's 5.5" Back Space....most likely will rub the leaf springs with any tire.
post #8 of 14 (permalink) Old 08-06-2009, 01:29 AM
Yeah a 4x4 what about a 20x10 with -13mm offset
clawson is offline
post #9 of 14 (permalink) Old 08-06-2009, 01:31 AM
the site says 5" backspacing on the 20x10
clawson is offline
post #10 of 14 (permalink) Old 08-06-2009, 01:34 AM
RDRCM
CooterBrown's Avatar
5" backspacing rubs on 2WD with 305.
#49
Sold
2006 Almighty CumminGs
CooterBrown is offline
