My Speedo stucky - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 07-14-2009, 03:22 AM Thread Starter
SmokeWithEveryStroke's Avatar
My Speedo stucky
No I don't wear a banana hamick. My dd is a early 99 reg cab 6spd. Last week I had some trouble with the batteries they were low in the mornings when I would go to start. Charged them, it started and it was fine all day. Happended a few more times then they were pretty much junk would only hold 6.7volts. New batteries yesterday and it was fine today except I get in go down the road and the speedo says 70-75. So drive down the innerstate go faster than 75 and it picks up. Get off the exit and still stuck. Come home still stuck, dissconect the batts and stays up, unplug the rear end sensor and still up. Put it on 2 jack stands and run it up to the speed limiter 97 or so. Stop the wheels turned it off and now its barried way past 100. Drove it to sb game it moved back to 75 turn the key off and it went all the way up again. Sorry its a long post but figured it would save the questions.
Help
99 ExCab Sb 6spd pulling truck (PULL-N-PRAY)
08 cclb
SmokeWithEveryStroke is offline
post #2 of 4 (permalink) Old 07-14-2009, 06:35 AM
Layson's Avatar
Re: My Speedo stucky
How is your shifting? Does it still shift when it is supposed to? I have seen the speedo recorrect itself after a similar issue...
Did you run your truck up to 97 while you it was on jackstands... wow!!
Layson is offline
post #3 of 4 (permalink) Old 07-14-2009, 01:54 PM Thread Starter
Its a six manual and it seems to shift fine. I did run it up to 97 on stands. I know I know its not safe but little things being broke or screwed up bug the crap out of me. I will do just about anything once twice if it works. I dont see why if the batteries are dissconnected how the speedo is staying up with now juice.
08 cclb
post #4 of 4 (permalink) Old 07-14-2009, 06:50 PM
fbilly420's Avatar
I have run into this problem many of times with chevys. Not sure if it will be the same. On the chevys I have always had to replace the instrument cluster.
2001 F250, CCSB, 4X4, Auto, Forged rods
Lots of go fast parts and still slow.
2001 F250, STD cab, 2WD
Frame is a little shorter now
workin on body
engine build underway
fbilly420 is offline
