08 axle in an 01 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 19 (permalink) Old 07-10-2009, 02:03 PM Thread Starter
Lovin the Tuna
RedSmokey's Avatar
08 axle in an 01
Is it difficult to put an 08 rear axle into an 01? does anything need to be modified (leafspring mounts, shocks, etc.)?
Just wondering what it would take to do it.
2001 F250
2000 F250
RedSmokey is offline
post #2 of 19 (permalink) Old 07-10-2009, 02:21 PM
6.0 money pit
smokinstroker's Avatar
Re: 08 axle in an 01
why the change?
smokinstroker is offline
post #3 of 19 (permalink) Old 07-10-2009, 02:35 PM
Lost Cause
Betaracer's Avatar
Shock mounts for sure. Up through 2004 the shocks were both on the rear of the axle. From 2005 on, one shock is forward and one rearward. Should just be able to remove the mount and reinstall in the desired place.
I believe the spring pads are centered the same. Only the Cab/Chassis version have wider a spacing, but that is the case with all model years.
2016 F-350, FX4, CCLB, 6.7PSD, 7" OUO/ICON/FOX lift, 38x13.50-18 Toyo MT
Betaracer is offline
post #4 of 19 (permalink) Old 07-10-2009, 02:36 PM Thread Starter
Lovin the Tuna
RedSmokey's Avatar
Originally Posted by smokinstroker View Post
why the change?
Just a small part of a lot of possible changes. Just brainstorming right now. But thinking of doing either 05-07 or an 08+ complete suspension/axle swap Along with a few other things, but like i said, just brainstorming. But i do want to start collecting parts soon as i find good deals...
What do you mean by that? And does that mean i can just re-use my u-bolts that are on now and the axle will bolt right into place w/ the springs without any modification? (aside from the shocks)
2001 F250
2000 F250
post #5 of 19 (permalink) Old 07-10-2009, 03:34 PM
<--Spy Vs. Spy
theSLEEPER's Avatar
Just so you know, you're not "supposed" to reuse u bolts...
So why are you doing this?
228-365-0698
Sheep only have two speeds, 'grazing' and 'stampede'.
Regulated Returns are on SALE!!
theSLEEPER is offline
post #6 of 19 (permalink) Old 07-10-2009, 03:39 PM Thread Starter
Lovin the Tuna
RedSmokey's Avatar
I know... And im just looking at possibly doing an entire suspension/axle swap to a newer truck with coil front springs. But i have a pretty good idea what im looking at for the front, and i want to know what im looking at for the rear...
2001 F250
2000 F250
post #7 of 19 (permalink) Old 07-10-2009, 04:06 PM
<--Spy Vs. Spy
theSLEEPER's Avatar
Why in the HELL would the rear matter??????? You'd be wasting money.
228-365-0698
post #8 of 19 (permalink) Old 07-10-2009, 05:06 PM
I put both axles and the front suspension from a '08 in my '97 so it can be done. You will need a few things nothing major. New custom parking brake lines or rob the '08 stuff..might be needed..
'08 rear has larger rear brakes I belive, never paid attention ...front sure has!
email:
Website:
OBSWIZ is offline
post #9 of 19 (permalink) Old 07-10-2009, 05:39 PM
<--Spy Vs. Spy
theSLEEPER's Avatar
I can definately understand the front axle and suspention, but unless the brakes are MUCH bigger on an 08 rear, seems like a hell of a lot of work and money unless your current gears and axles have problems... Or if you have an OBS.
228-365-0698
post #10 of 19 (permalink) Old 07-10-2009, 05:41 PM
treyloco's Avatar
If I remember right I think the stud pattern is different 05 up.
'03 7.3 lariat crew cab dually FX4
AFE Stage 2
DI 6 position
warn premium hub locks
4" mbrp straight piped exhaust
custom built trans w/ triple disc converter
'07 Front End w/ 6000k HID
AIH delete & CCV Mod
Just over 100k miles
"Powerstroke Performance Headquarters!"
treyloco is offline
