will 07 20" wheels work on a 2000??? 2wd - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 21 (permalink) Old 07-03-2009, 02:37 PM Thread Starter
i am about to get some factory 20" wheels and tires off a 2007 will they work on the 2000 without any issues i know the 08s are diffrent.
BOTLDPONY is offline
post #2 of 21 (permalink) Old 07-03-2009, 04:18 PM
Proud Sponsor
Abrannan19's Avatar
Re: will 07 20" wheels work on a 2000??? 2wd
yes they will work,but they will rub on the springs at full lock turn. Only way to correct that is with some 1/4" spacers/adapters
Adam Brannan
Email
Phone (904)-813-5067
2011 F350 KR SWB CC 4x4 tuned by Ford
Abrannan19 is offline
post #3 of 21 (permalink) Old 07-03-2009, 05:56 PM
RDRCM
CooterBrown's Avatar
More like a 2" spacer. It will rub the radius arm on your 2wd. If you run them without you should also pay close attention to rubbing the flexible brake line.
CooterBrown is offline
post #4 of 21 (permalink) Old 07-03-2009, 06:23 PM Thread Starter
so do i need a pair of spacers just for the front or do i need all four spacers? so the rear is not sucked in as well.
post #5 of 21 (permalink) Old 07-03-2009, 06:39 PM Thread Starter
if i need all four i will probably pass on the wheels i can get them for $475 and they need two tires then four spacers. i would have $850 in all of it when i could buy some aftermarket ones for that price.
post #6 of 21 (permalink) Old 07-03-2009, 07:35 PM
RDRCM
You would need (4) 2" spacers.
post #7 of 21 (permalink) Old 07-03-2009, 09:16 PM
F250 Black Cloud Edition
Gotti2k7's Avatar
If the wheels come off a 4wd. And they are going on a 2wd. You HAVE to get the Hubcentric spacers. The wheels are centered on the hub. That or you would have to get the wheels counter sunk, and get tapered nuts. The wheels do work without spacers. But they do rub. And looks kinda funny being in so far.
02 F250. Turbonetics, SRP1, Tim from P.I.S built Hybrids, Built Trans, Afe Stage 2, HPX line. Tuned by Jonathan from Beans, 4 inch exhaust, with the muffler. Triple Phantom 2 gauges. Forged Rods and with another block. 500hp.
Gotti2k7 is offline
post #8 of 21 (permalink) Old 07-03-2009, 09:53 PM
RDRCM
So you think Ford makes a 2wd and a 4wd wheel. You think 2wd trucks are not hubcentric and you should counter sink them. You're an idiot, stop offering advice.
#49
Sold
2006 Almighty CumminGs
post #9 of 21 (permalink) Old 07-04-2009, 02:16 AM
JimTJr's Avatar
I thought the wheels were allot different on the 05s and up?
Old ones were 8x170 and the new ones were different? Is it ONLY the center that is a different size? And the lugs fit?
*48* Jim T. 2011 F-350 Lariat, CC, LB, SRW. White Platinum Metallic Tricoat. Black leather seats, I probably wont have*PMS,, with this one, at least no major attacks of it!
JimTJr is offline
post #10 of 21 (permalink) Old 07-04-2009, 05:04 AM
RDRCM
The only difference is the backspacing.
