any ideas on how to fit these tires.Help!!! - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 22 (permalink) Old 06-30-2009, 05:44 AM Thread Starter
00powersmoke's Avatar
i got some 33'' 15.50 baja claws an they came in today an theres no way in hell there gona fit. anyone else ever put this size tire on an what did you do to pull it off. im lookin to get around liftin it to much i can't use it to work again but still look different.
00 f-250 Lariat 4x4,CC,SB
00powersmoke is offline
post #2 of 22 (permalink) Old 06-30-2009, 01:14 PM
recon250's Avatar
Re: any ideas on how to fit these tires.Help!!!
cut away flares
02 f-250 xlt with leather, BTS trans. dp-tunes, afe. 40" bfg km2 on some 20's. and a bunch of other stuff that doesent make it any faster.
recon250 is offline
post #3 of 22 (permalink) Old 06-30-2009, 01:27 PM
Stroker67's Avatar
Leveling kit
Stroker67 is offline
post #4 of 22 (permalink) Old 06-30-2009, 01:39 PM
Lovin the Tuna
RedSmokey's Avatar
cut away flares (like bushwackers) would probably be best for clearences, along with a properly sized wheel/backspace. If you dont want to cut you probably could do the leveling kit but no matter what you will need the right size/backspace wheel to keep from rubbing spring like crazy. My .02
2001 F250
2000 F250
RedSmokey is offline
post #5 of 22 (permalink) Old 06-30-2009, 01:40 PM
<--Spy Vs. Spy
theSLEEPER's Avatar
Whatever you do... I wanna see a picture of it with them on there!!
228-365-0698
Sheep only have two speeds, 'grazing' and 'stampede'.
Regulated Returns are on SALE!!
theSLEEPER is offline
post #6 of 22 (permalink) Old 06-30-2009, 01:43 PM
Lovin the Tuna
RedSmokey's Avatar
I was thinkin of droppin down to a 4" and some 34"-35" tires when the ones i have now are gone, but i want to see what this looks like with these wide azz tires.
2001 F250
2000 F250
post #7 of 22 (permalink) Old 06-30-2009, 01:50 PM
<--Spy Vs. Spy
theSLEEPER's Avatar
If I went to 33's, I think I'd have to swap gears... 3.23's or something like that...
228-365-0698
post #8 of 22 (permalink) Old 06-30-2009, 01:53 PM
Lovin the Tuna
RedSmokey's Avatar
same here, but it sounds like he is already running on some stock sized tires...
2001 F250
2000 F250
post #9 of 22 (permalink) Old 06-30-2009, 02:18 PM Thread Starter
yeah pretty much stock 285's, an still the stock 3:73s.
what kinda back spaceing to you think ill need. i need to figure out some numbers so i can get them on. my 285's are in bad shape.
post #10 of 22 (permalink) Old 06-30-2009, 02:57 PM
<--Spy Vs. Spy
theSLEEPER's Avatar
What size wheels are you running?? If I were you, I'd buy a leveling kit. They can be had for cheap, and after that... turn back and forth and cut any offending areas away...
228-365-0698
