Dynatrac Freespin question - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 06-30-2009, 02:25 AM Thread Starter
Members:
Has anyone had any first hand experience installing a Dynatrac Freespin kit on a '99-04 SuperDuty Dually?
I have installed several on SRW applications but have never installed the kit on a DRW. Dynatrac advised that a special dually adapter must be ordered and installed which they do not sell, but is to be purchased from Arrowcraft in MI. Other I have talked to said only the casting flash on the inside of the factory dually hub adapter needs to be removed and you are good to go?
If you have information in regards to this portion of the install I would Greatly appreciate it!
Thanks,
Chet
Chester is offline
post #2 of 2 (permalink) Old 06-30-2009, 08:03 PM
Re: Dynatrac Freespin question
I have READ that you can either remove the "casting flash" or put the hub adapter on after the lockout hub is installed.
1999 F350 6SPD 4x4 LARIAT Tymar, DP-F5, ITP Reg Return, 4" Exhaust **SOLD**
2002 F350 REG CAB DRW 2WD Tymar, PHP, 5" stack, DJM drop hangers and shackles, Hellwig sway bars, Nathan K5LA, Full Power '08 Mirrors...**SOLD**
DIRTBIKEZ is offline
