How many leafs in a front leaf pack. - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 11-26-2007, 06:01 AM Thread Starter
heep70's Avatar
Not sure if my 2000 4x4 has the right leveling kit. Seems the front leaf packs are saggy and they also looked to be bent weird around the spring pads.
Anywho, my questions are how many leaves are in a stock spring pack on a F250 4X4 crewcab?
And is there an add a leaf kit for the front packs?
Greg
2000 PSD F250 4X4 Crew, John Wood 4R100, DP Tuner, 4" Diamond eye, Tymar, LIFT, 35" Toyos, Pillar gauges, TC lockup switch, 6.0L cooler, Single core rad, Most of all a Cool Driver, THATS ALL.
heep70 is offline
post #2 of 8 (permalink) Old 11-26-2007, 06:09 AM
Back to Civilian Life!!
MILFORD's Avatar
Re: How many leafs in a front leaf pack.
There is only 2 in the pack.
2003 F-250 4x4 7.3 liter PSD EXT. cab SB. Wilson 2000 antenna, Uniden PC78 peaked and tuned with a connex 250 Linear Amp.
MODS: BTS Tranny, DIY Tymar, Hypermax 3.5 DP to 5" back, TW tunes, DI's GT38R BB turbo, autometer boost, pyro, trans, water temp a Scangauge and Firestone rear air bags.
MILFORD is offline
post #3 of 8 (permalink) Old 11-26-2007, 06:09 AM
Crazy Redneck
UNCOOL's Avatar
Stock front pack has 2 leafs. Best to get a leveling kit pack.
Marc
2000 F350 CC dually auto
Little air, fuel and oil and a BTS.
533/1050 5-8-10
#32
UNCOOL is offline
post #4 of 8 (permalink) Old 11-26-2007, 08:34 AM Thread Starter
heep70's Avatar
So four all together counting the main spring and load spring? I have 5 all together. Guess it allready has the add a leaf and the are ready for replacement. They just don't look right being bent the way they are. Almost a "w" look to them.
Greg
heep70 is offline
post #5 of 8 (permalink) Old 11-26-2007, 11:39 AM
< pissed off pumkin.
skylinedan's Avatar
Talking Re: How many leafs in a front leaf pack.
You have 2 (TWO) leaves in the front springs, you add a leaf to the bottom of the stack. The rears have 4 and then a block and a helper, But thats if you have the HD suspension. I have a F250 with 350 suspension basicly.
Dan
2003 F-350 4x4, Ext cab. 7.3 AFE stage II 4" turbo back exhaust, garret GTP 38, 1.15 van turbine housing,EBPV deleated, non waste gated, ATS compresor housing, WW II, bellowed up pipes, CFM + spyder conversion, Hydra chip with Bill's tunes, CCV mod, Hutched, harpooned, RR fuel system, 6.0 trans cooler, Swamps IDM, HPX.
skylinedan is offline
post #6 of 8 (permalink) Old 11-27-2007, 01:10 AM
Edward Scissorhand WanaB
Bushwakd's Avatar
The stock springs will actually have a sagging look to them which is normal as they have a negative arch to them.( Example) look at a 1996 stock front leaf spring pack that has a positive arch to it and compare that to a 1999 stock front leaf spring pack that has a negative arch to it. While traveling the positive arch spring will bounce from a positive arch to a negative arch and back to positive and so on creating a bounce and hammering effect. When traveling with a negative arch spring pack the spring will stay negative and sag and then go to a positive arch and return back to the negative state in turn giving a smoother ride as Ford tells us. Think of the positive arch and the negative arch for a moment and apply that to what I explained. Does it make sense? (Flame suit on)
In any event my stock 2000 F-250 has two front leafs and my stock early 99 F-450 has two front leafs. Some claim that a sag difference from right to left in springs and a replacement is needed. (And they will have a sag also because of the negative arch.)
"Real Trucks Don't Have Sparkplugs"
2000 F-250 Lariat, CC, 4x4, LWB,
A few mods to make it better than stock.
250cc hybrids, Stealth stage II HPOP, H-11 Headstuds, Strickly Diesel Reg. Return Fuel, Spearco 6.0 IC, Garrett 38r 1.15 hsg, BTS transmission, Gearhead Tuning
"The Smoke Don't Mean Its Broke"
Bushwakd is offline
post #7 of 8 (permalink) Old 11-27-2007, 01:35 AM
well, mine has 3 leaves per side... Some sort of add-a-leaf? Maybe RoughCountry(sticker on the window when I bought it)?
Chase
99 S/C shortbox, 7.3, auto, 4wd 315s
4" DP, zoodad, gauge package
TWildman. 6pos. Flipper Chipper, 4" turbo back
A wise man once said; "Nitrous is like a hot chic with a STD..."
"You know you wanna hit it, but you're affraid of the outcome"
Life is like a jar of jalapenos. What you do today, might burn your a$$ tomorrow'.
chasespeed is offline
post #8 of 8 (permalink) Old 11-27-2007, 08:38 AM Thread Starter
heep70's Avatar
My rig has a small lift. I am running 35" tires. The front spring pack has 5 leaves alltogether and so does the rear leaf pack plus the helper and blocks.
Greg
heep70 is offline
