Rear Block help - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 19 (permalink) Old 06-26-2009, 03:46 PM Thread Starter
BigTonka's Avatar
Rear Block help
Ok this past weekend I finnally got to install the 4" blocks that I have had for over 3 years . Now for the problem I oredered the blocks, u-bolts, and drive shaft hanger from powerstrokeshop.com well they sent me the wrong drive shaft hanger and now I have a vibration when I leave the line hard (all the time lol). Does anyone know the right part # for the hanger that goes with the 4" rear blocks??
Thanks,
Brian
2006 F-250 CC SWB Amarillo with all the toys:
CAT back MBRP SS system, pillar gauges (ext,boost, trans, temp) cobra 29, rear flood lights installed F350 emblems in place of the 250's
and one freshly removed PSN sticker!!!!!
BigTonka is offline
post #2 of 19 (permalink) Old 06-26-2009, 03:48 PM
bigaF250's Avatar
Re: Rear Block help
why did you do blocks and not just leafs watch that axle you will send that son of a bi##h out the azz end
bigaF250 is offline
post #3 of 19 (permalink) Old 06-26-2009, 03:49 PM
bigaF250's Avatar
Re: Rear Block help
o you might just need to have your driveline ballanced
bigaF250 is offline
post #4 of 19 (permalink) Old 06-26-2009, 05:01 PM
tbolt's Avatar
Re: Rear Block help
wrong angle on the driveline will (could) cause the u joint to bind. And if you are racing and such, between the shaft issue and those blocks you are flirting with an accident, imo
Glen
early99 f350 cc, lb, 2wd, drw, A pillar autometer guages, CTS monitor, AIS intake, 4" turbo back cat delete diamondeye exhaust, dptuner, pmt1, jw vb, Swamps ab inj, Adrenaline oil, Coolingmist, 180*T, Trucool cooler, spin on trans filter, Firestone air bags, 2" frt leveling kit, now chased by a 34' toyhauler
tbolt is offline
post #5 of 19 (permalink) Old 06-26-2009, 05:06 PM Thread Starter
BigTonka's Avatar
Re: Rear Block help
All I did was install the factory taller blocks they are not even 4 inches tall so its all good.
tbolt that is correct I need to have the proper drive shaft hanger so the angle is right. I did not have the vibration before I did the new blocks
BigTonka is offline
post #6 of 19 (permalink) Old 06-26-2009, 05:12 PM
Re: Rear Block help
You may need spacers for your carrier bearing. Just shim it with some flat 1/8" or 1/4" stock. Keep adding shims till the vibration goes away.
2001 F350 CC SWB 6spd .......currently undergoing a makeover.....stay tuned.
LOOSEWHEEL is offline
post #7 of 19 (permalink) Old 06-26-2009, 05:18 PM
All done now
Arisley's Avatar
Re: Rear Block help
Arisley is offline
post #8 of 19 (permalink) Old 06-26-2009, 06:26 PM
Laces Out
bigrpowr's Avatar
Re: Rear Block help
Carrier shims will fix it guaranteed.
08' F250 4x4 w/ 3:55's
bigrpowr is offline
post #9 of 19 (permalink) Old 06-26-2009, 06:48 PM
Re: Rear Block help
to me, if you installed the factory 3 5/8 blocks, you should not need shims in under your hanger brg. my truck is the same truck, mind you an 03. but same wheelbase and cc as well. it came stock with the 3 5/8 block and it also had no shims. or am i not reading your question right??
2003 CC F350, ARP'S, HOMEMADE EGR DELETE, 4.5" ICON LIFT, MBRP, ZOODADED, NEW FUEL SYSTEM SOON, 05 FRONT END, AND A SLEW OF OTHER STUFF
TUNED BY DJ, ERIC, AND CALE
03ccf350 is offline
post #10 of 19 (permalink) Old 06-26-2009, 07:07 PM
TxFireman1972's Avatar
Re: Rear Block help
Like the above post said, not sure why you would need it. My truck is F350 and came with the bigger blocks and had no carrier spacer. Here is a decent price on a kit at TruckToyz. Call them if you want, they will make sure get what you need:
http://www.trucktoyzstore.com/realm/...idcategory=369
2005 F350 Crew Cab 4x4
PMF Rear Leaf Spring Conversion w/2011 Leaf Springs
20" Harley Wheels 305/55/20 Nitto Terra Grapplers
SCT X3 w/GearHead Tunes
Amp Steps, Bedrug, HID's
TxFireman1972 is offline
