slip tank ??? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 06-21-2009, 08:49 PM Thread Starter
slip tank ???
can anyone give me a idea on how to hook up my slip tank like a gravety feed to main tank? thanks
Blackmax is offline
post #2 of 4 (permalink) Old 06-22-2009, 06:22 PM
Custom Trailer Sales
TrailerHauler's Avatar
Re: slip tank ???
Maybe put a "T" into the fill neck?
1999.5 F350 PSD CC Dually 05' Conversion
Stage I's - Gearhead Tuning - BTS - PCS
F550 rear suspension
1999.5 F350 PSD S/C 6spd Dually
R.I.P. Will Iott - "This ain't no practice run"
TrailerHauler is offline
post #3 of 4 (permalink) Old 06-22-2009, 06:26 PM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
Re: slip tank ???
Pull your filler neck, Drill a 3/4" hole in it. weld a steel fitting on to it and thread a barbed fitting into it. I used 3/8" hose IIRC, maybe even 1/4". Then your tank has a drain fitting and do the same thing there, only I added a Ball valve so I could turn it off if parked for a long time or if running red and I dont want to risk it.
BTW, I have done this on every pick up I have owned, the 95,97,99 and the 01. All the same way.
Joe
CSIPSD is offline
post #4 of 4 (permalink) Old 06-23-2009, 02:22 PM Thread Starter
Re: slip tank ???
thankyou.... that helps and explains alot to what i need to do...
Blackmax is offline
