alinement?? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 11-15-2007, 02:40 PM Thread Starter
morepower02's Avatar
alinement??
I installed 2 inch spacers between the front axle and coil springs, the Ford dealer just called and said they cant aline it without a longer track bar
They say because the axle shifted to the side a little they cant do it. Does this sound right??
morepower02 is offline
post #2 of 9 (permalink) Old 11-15-2007, 02:41 PM
Banning Smut
PTSUPERD's Avatar
Re: alinement??
Doesnt sound right with only 2" of lift???
If it's true, get an adjustable trackbar from Fabtech. Think I paid like 120 for mine?
PTSUPERD is offline
post #3 of 9 (permalink) Old 11-15-2007, 02:59 PM Thread Starter
Re: alinement??
I know it sounds odd. I checked out fabtechs 2 inch kit and it is just blocks and shocks. They must not figure one is needed. I wonder if the dealer is just being difficult
post #4 of 9 (permalink) Old 11-15-2007, 03:07 PM
Power Stroke's Avatar
Re: alinement??
well it depends what they told you couldnt be aligned, because the toe, steer ahead, caster and camber arent affected by the leveling kit. the only thing that it will throw off is the center line because the front axle is off center, the steering wheel might me slightly off center to but that can also be adjusted.
2006 F350 Oxford White Sport SC/SB 4x4 - Exhaust & SCT w/Innovative Diesel Tuning.
retired nitrous pig 12.68 @ 106
Power Stroke is offline
post #5 of 9 (permalink) Old 11-15-2007, 03:14 PM Thread Starter
Re: alinement??
they say they cant do it because the axle is shifted to the side. I am going to try a different shop
post #6 of 9 (permalink) Old 11-15-2007, 03:28 PM
Re: alinement??
theyre full of it, i work at a dealer and im sorry to say service departments are an entire pain in the ass, i am an employee here and very knowledgable with cars/trucks and i can not believe how they treat me. my 99 has a leveling kit in it and they just aligned it for me the other day.
post #7 of 9 (permalink) Old 11-15-2007, 05:18 PM
BUFF's Avatar
Re: alinement??
Its I have a 2 1/2" spacer and did not need an alignment did you drive it if it goes straght and the wheel isnt crooked dont worry about it.
06 F350 CC LB 4x4 with a few odds and ends
BUFF is offline
post #8 of 9 (permalink) Old 11-16-2007, 02:13 AM Thread Starter
Re: alinement??
I am going to install the skyjacker 2 inch drop trackbar bracket. That way the axle will be straight. Figured it would give me a little more piece of mind knowing that the new tires will probably last longer. I think the reason the axle shifted that much was that my truck has the heavy service snowplow front springs so the front end was already pretty high. Now 2 inches higher yet and the front is level with the back and it a f 350 so the back sits high.
post #9 of 9 (permalink) Old 11-16-2007, 09:06 AM
BUFF's Avatar
Re: alinement??
I dont think you should need it you may want to take it to a shop that does alot of lifted trucks. If your steering wheel is straight I doubt the axle has moved much. Also the drop bracket without droping the steering may throw off the geomitry and give you a bad case of bump steer.
BUFF is offline
