A/C and Heater Question - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 11-10-2007, 06:05 AM Thread Starter
Superstroker1's Avatar
Send a message via MSN to Superstroker1
So i was getting in my truck the other morning and put my heater to defrost like every other morning and headed off to work i got about half way to work and went to swich it to come out of the vents but it just stays on the defrost no matter which setting the control switch is on has this happened to anyone else?
Thanks
Gib
2000 Ford F-350 Crew Cab Long Bed
7.3 Powerstroke
ATS 4 inch Exhaust
Flip Chip Stock/50/100/150 hp
AFE Stage One Intake
Sun Coast Converter
Mag HY Tranny Pan
8 Inch Lift in Front
9 Inch In rear
2006 Badges
Apc Head Lights
Two Twelve Inch Subs Powered by a 950 watt Amp
Superstroker1 is offline
post #2 of 6 (permalink) Old 11-10-2007, 06:11 AM
Hated by All
Fast_Ashley's Avatar
Re: A/C and Heater Question
Vacuum pump.
When it goes out it defaults to defrost so you can at least see out of the windshield.
PARIAH
2001 F-350
Resurection has begun.....
Fast_Ashley is offline
post #3 of 6 (permalink) Old 11-10-2007, 06:50 AM Thread Starter
Is that hard to replace and is it expensive
7.3 Powerstroke
ATS 4 inch Exhaust
Sun Coast Converter
Mag HY Tranny Pan
9 Inch In rear
2006 Badges
Apc Head Lights
post #4 of 6 (permalink) Old 11-10-2007, 06:52 AM
Hated by All
Pump is under a hundred, not bad to replace at all.
Located on the pass. side inner fender next to all that A/C crap.....
PARIAH
2001 F-350
post #5 of 6 (permalink) Old 11-10-2007, 07:02 AM Thread Starter
sounds good ill look in to it tomarrow
7.3 Powerstroke
ATS 4 inch Exhaust
Sun Coast Converter
Mag HY Tranny Pan
9 Inch In rear
2006 Badges
Apc Head Lights
post #6 of 6 (permalink) Old 11-10-2007, 03:34 PM
All done now
Arisley's Avatar
Check the vacuum lines first.
Arisley is offline
