Ball Joint ? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 11-08-2007, 12:54 PM Thread Starter
Peon
jvencius's Avatar
jvencius is offline
post #2 of 8 (permalink) Old 11-08-2007, 02:14 PM
Sleep well my brothers
yamt03's Avatar
Re: Ball Joint ?
I think the dude is high on crack. I have never heard of anything wrong with Moog. I have had duralast produsts in the past that didn't last so I would go with Moog and not worry about it. Maybe the fumes from his chebby has givin him dain bramage.
Early 99 CC DRW AFE, 4" MBRP,Autometer,6.0 trans cooler, ITP, DP Tuner and cupholder upgrade
Former U.S.A. Res. MP & proud of it!
2005 Dodge 4x4 5.9 With some stuff done to it.
"If you voted for Obama in 2008 to prove you're not a racist…you'll have to vote for someone else in 2012 to prove you're not an idiot."
yamt03 is offline
post #3 of 8 (permalink) Old 11-08-2007, 06:46 PM
fbilly420's Avatar
Re: Ball Joint ?
wrenchin is what I do for a living and moog is the only way to go. You should go back to AZ and tell that guy he should grease his ball joints.
2001 F250, CCSB, 4X4, Auto, Forged rods
Lots of go fast parts and still slow.
2001 F250, STD cab, 2WD
Frame is a little shorter now
workin on body
engine build underway
fbilly420 is offline
post #4 of 8 (permalink) Old 11-09-2007, 04:22 PM
Village Idiot
southmike's Avatar
Re: Ball Joint ?
lol
southmike is offline
post #5 of 8 (permalink) Old 11-09-2007, 07:23 PM
aklim's Avatar
Re: Ball Joint ?
Was it installed properly? Did they lube it up properly? How often has it failed? Those are important questions. Moog is the cats meow. not sure about it's azz.
Sounds like someone is trying to push their products.
01 Excursion 7.3L Powerstroke. Gauges with AIH Delete, AIS, CCV Mod, 4' MBRP, BTS Trans, 6.0L Trans Cooler and Intercooler, DP-Tuner F5 chip, ITP In Tank Mod and Boost Annihilator, Diesel Innovation's Regulated Fuel kit, BTS Big Oil system, GTP38R Turbo with 1.15 A/R housing and BPD Stage II AC injectors. Bilstein Shocks with U front and A Rear.
aklim is offline
post #6 of 8 (permalink) Old 11-09-2007, 09:32 PM
Re: Ball Joint ?
Cant go wrong with Bob's kit from the PowerStrokeShop.
1999 F350 6SPD 4x4 LARIAT Tymar, DP-F5, ITP Reg Return, 4" Exhaust **SOLD**
2002 F350 REG CAB DRW 2WD Tymar, PHP, 5" stack, DJM drop hangers and shackles, Hellwig sway bars, Nathan K5LA, Full Power '08 Mirrors...**SOLD**
DIRTBIKEZ is offline
post #7 of 8 (permalink) Old 11-10-2007, 03:58 PM
Hated by All
Fast_Ashley's Avatar
Re: Ball Joint ?
PARIAH
2001 F-350
Resurection has begun.....
Fast_Ashley is offline
post #8 of 8 (permalink) Old 11-10-2007, 04:11 PM Thread Starter
Peon
jvencius's Avatar
Re: Ball Joint ?
That's who I figure on ordering from when the time comes. I'm saving up for a Dynatrac kit and while I have the front axle that torn apart, I might as well do the ball joints at the same time.
jvencius is offline
