TO ALL WITH STACKS - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 23 (permalink) Old 10-30-2007, 07:59 PM Thread Starter
TO ALL WITH STACKS
what size pipe do you have coming through the bed? looks like theres gonna be some stuff in the way for my 5" to come through. anyone got pics of how they did there's?
PMRCM#1
slowleak is offline
post #2 of 23 (permalink) Old 10-30-2007, 08:15 PM
OBS junkie
Cat_Rebel's Avatar
Re: TO ALL WITH STACKS
You can't run them right up against the front of the bed because of the cross member (brace) on the bed. If you move it back a few inches you'll be just fine. I run 3.5" on mine because I already had two adapters to go from 2.5"-3.5" on my IDI.
97 F350 CCLB "Da Bus"
RIP Will Iott
"This ain't no practice run"
Cat_Rebel is offline
post #3 of 23 (permalink) Old 10-30-2007, 08:30 PM Thread Starter
did u torch that hole or cut it with a saw? i have to go take another look cause if i remember right my crossmember would put everything against the back of the bed
PMRCM#1
slowleak is offline
post #4 of 23 (permalink) Old 10-30-2007, 08:59 PM
OBS junkie
Cat_Rebel's Avatar
We took the torch to my bed because we left the hole saw at home & as you have seen my bed needs to be replaced sooner or later. For my Ma's & buddy's we just went down to Home Depot & bought a hole saw that was about an 1/8 to a 1/4" over size & you'll get a nice perfect hole. It is worth the money to get the hole saw when your going for a clean look. Unless you have a plasma cutter!
RIP Will Iott
post #5 of 23 (permalink) Old 10-30-2007, 10:18 PM
<<<<< Next Generation
boggerr's Avatar
Mine is thru part of the brace under the bed, my measurement mistake, but it is closer to the front bed and its not much of that brace cut out. I actually liked making that mistake.
Pipe thru the bed is 4"
I used a hole saw
N.E. Terminator Tech
2000 F350 Lariat CC 4x4 LWB Auto
DP-Tuner F5, Terminator HPOP, QSSB, ITP's fuel system, BTS trans.
boggerr is offline
post #6 of 23 (permalink) Old 10-30-2007, 10:33 PM
OBS junkie
Cat_Rebel's Avatar
There was a guy on TDS with a white OBS that pulled out the cross piece to fit them right up next to the bed. He did that so he could still have his 100 gallon fuel tank in the bed too. He said even with all of that fuel he never had an issue.
RIP Will Iott
post #7 of 23 (permalink) Old 10-30-2007, 10:37 PM
Cummins Power
mech2161's Avatar
I used a hole saw
This is the same as mine. I did come through the middle of the bed. Not offset.
Kevin
12v CONVERSION IN PROGRESS, Special thanks to:
South Bend Clutch, MOTORSPORTSSUPPLY.COM, Pure Diesel Power & Performance, Carson Stauffer Diesel Service, Weston Shupe, zstroken
mech2161 is offline
post #8 of 23 (permalink) Old 10-30-2007, 10:44 PM
OBS junkie
Cat_Rebel's Avatar
The only problem with the middle is that you usually run into driveshaft issues on a stock or 2wd truck. I know a guy that had a 4" exhaust going over to the middle but he also had a 4" lift on the truck. He pulled the stacks off & also dropped his truck back to stock height. We were looking at it & figgured that it would be too tight of a gap & too close the the driveshaft if he were to try it now. Not sure about the Superduty but that's how the OBS Dodges are.
RIP Will Iott
post #9 of 23 (permalink) Old 10-31-2007, 03:43 AM
Dieselized
bluetech151's Avatar
what are you going for the look or sound?
You call yourself a mechanic, you can't even fix a mechanical pencil.
bluetech151 is offline
post #10 of 23 (permalink) Old 10-31-2007, 04:30 AM
<- Sums it up
strokin_early_99's Avatar
Pics of mine can be found here: http://community.webshots.com/album/559624712RzHptn
I used a sawz all. I drew it with a pen first and drilled a 1" hole in the center and attacked it in small pie shapes. Then cut each off and trim it up. All I used was a sawz all, nothing else. It worked great. I am a carpenter by trade so this I do in the field all the time. And yes, a sawz all is a finish tool, no matter what Norm Abrams says.......
Early99 CC LWB 4X4
Updated B codes, Modded H2E, Big oil, half filled block, studded, John Wood 4R100. 232K miles
Tows like a champ!
"Damn Larry, he passed us like a freight train passing a hobo!"
--Lisa P.
Just sold to Larry
2-17-2019: 97 CC LWB 4X4 7.3 with full banks kit, John Wood E4OD. 139K miles
strokin_early_99 is offline
