Lowering kits? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 16 (permalink) Old 10-30-2007, 12:14 AM Thread Starter
SeeYa's Avatar
Lowering kits?
Ok guys, we will be lowering the Excursion.
What will this process intel with a 4x4? I am thinking 2 inches, max.
Thanks,
Diane
SeeYa is offline
post #2 of 16 (permalink) Old 10-30-2007, 03:23 AM
All done now
Arisley's Avatar
Re: Lowering kits?
To tall to get into?
Arisley is offline
post #3 of 16 (permalink) Old 10-30-2007, 03:25 AM
Dieselized
bluetech151's Avatar
Re: Lowering kits?
try the axle over
You call yourself a mechanic, you can't even fix a mechanical pencil.
bluetech151 is offline
post #4 of 16 (permalink) Old 10-30-2007, 05:29 AM
OBS junkie
Cat_Rebel's Avatar
Re: Lowering kits?
Lowering? Come on Diane it's a 4x4!
97 F350 CCLB "Da Bus"
RIP Will Iott
"This ain't no practice run"
Cat_Rebel is offline
post #5 of 16 (permalink) Old 10-30-2007, 05:55 AM
Do you smell something?
Wackerjr's Avatar
Re: Lowering kits?
you need to look at the front axle and see how far you can go.....
That is the ONLY deciding factor in a excursion.....The axle hits the crossmember.
There is NO lowering kit for a 4wd usually, specially not an Ex.
You can have the front springs dearched, or try a flip axle, but that is going to be ALOT of drop, and I think would hit the crossmember....Prob the best way would be to have new springs made/dearched. Rear.....not sure but does the Ex have a block? just swap it out for a shorter one.
Wackerjr is offline
post #6 of 16 (permalink) Old 10-30-2007, 08:01 AM
BUFF's Avatar
Re: Lowering kits?
Or you could just get bigger rims and tires and have the illusion its lowered. Dosent kelderman have a air bag lowering kit for the x's
06 F350 CC LB 4x4 with a few odds and ends
BUFF is offline
post #7 of 16 (permalink) Old 10-30-2007, 11:57 AM
All done now
Arisley's Avatar
Re: Lowering kits?
Running boards, they make it appear to ride lower.
Arisley is offline
post #8 of 16 (permalink) Old 10-30-2007, 12:05 PM Thread Starter
SeeYa's Avatar
Re: Lowering kits?
Thanks guys...
I have the big rims and low profile tires already. Running boards came on it. I think it would look good just 2 more inches lower. I have also read around the forums that it makes it ride better on long trips.
Diane
SeeYa is offline
post #9 of 16 (permalink) Old 10-30-2007, 02:18 PM
Proud PSN Sponsor!
Strictly Diesel's Avatar
Re: Lowering kits?
Originally Posted by SeeYa View Post
Thanks guys...
Diane
Only if it's not so low that you're hitting the bumpstops!
Dennis Schroeder - Co-Owner of Strictly Diesel
Race Truck :: 6050# / 11.31 @ 120mph / Best 60' of 1.56 ... with "Built" Race Engine (Fuel Only!)
Race Truck :: 5980# / 10.965 @ 124mph / Best 60' of 1.54 ... with "Built" Race Engine (Nitrous)
Strictly Diesel is offline
post #10 of 16 (permalink) Old 10-30-2007, 02:40 PM Thread Starter
SeeYa's Avatar
Re: Lowering kits?
Yeah, I did that in the Beetle's all the time...
SeeYa is offline
