cowl hood - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 16 (permalink) Old 10-11-2007, 07:37 PM Thread Starter
Bill
badford350's Avatar
cowl hood
I just put mine on today. I was curious if you can make these functional? I cut a piece of the under hood insulation so that it would allow air flow by the tymar. I noticed small decrease in egt and running one pound of boost less at 75. It looks pretty good though
02 f350 larit, itp rr & pre pump filter, GTP38r, international up pipes, swamps 175/146 single shot's, DP tuner, factory tech valve body & lot of extra lights
badford350 is offline
post #2 of 16 (permalink) Old 10-11-2007, 08:44 PM
DILLIGAFF
Send a message via AIM to Redfish
Re: cowl hood
2006 F-250 CC King Ranch, Harley Headlights w/ 55w HIDs
ARP studs, MBRP 4" exhaust and AM Colbalts By:
, AFE stg. 2 Pro Guard 7 from XDP, SCT from innovative!
14.09 @ 94 1.85 60'
Redfish is offline
post #3 of 16 (permalink) Old 10-11-2007, 10:02 PM
OBS junkie
Cat_Rebel's Avatar
Re: cowl hood
Yes, it give you the room that you need for twins!
97 F350 CCLB "Da Bus"
RIP Will Iott
"This ain't no practice run"
Cat_Rebel is offline
post #4 of 16 (permalink) Old 10-12-2007, 11:57 PM
I love you bigrpowr!
QtrHorse's Avatar
Re: cowl hood
One little pc of advice. You cannot swing the passenger side windshield wiper arm up all the way now. It will rub on the top of the raised hood.
99.5 F250 XLT S/C 6SPD
I have no ring and no love from the mods.
QtrHorse is offline
post #5 of 16 (permalink) Old 10-13-2007, 12:57 AM Thread Starter
Bill
badford350's Avatar
Re: cowl hood
im glad you told me that it would have made a bad day If I found that the hard way. I would post a pic but its not working for me. I wont be able to tell for sure until my next road trip on the affects on mileage or power. that is to see if it was worth cutting the insulation to allow air flow to the filter.
I thought about hooking up ae and seeing what the intake air temps were then cover the hole and do a identical pass to see if they drop or not. not sure what other sensors to select to see if the hood helps at speed.
post #6 of 16 (permalink) Old 10-13-2007, 07:52 AM Thread Starter
Bill
badford350's Avatar
Re: cowl hood
hear are some links to the pictures. I couldnt get any load on the psn.
post #7 of 16 (permalink) Old 10-13-2007, 06:23 PM
QtrHorse's Avatar
Re: cowl hood
I had some buddies think it would be funny to lift both my wiper arms all the way one day after work.There is now a little section (maybe 3/4in) right on the back edge that is missing paint. After I told them what it did, they felt bad.
QtrHorse is offline
post #8 of 16 (permalink) Old 10-13-2007, 10:37 PM Thread Starter
Bill
badford350's Avatar
Re: cowl hood
I thought about getting some of the rubber trim for edge of a car door and placing it on the top of the cowl. or the entire lenght of the back side. this is what I was thinking of using.
http://www.jcwhitney.com/autoparts/P...001807/c-10101
post #9 of 16 (permalink) Old 10-13-2007, 11:44 PM
Re: cowl hood
The wiper scrapes happen- at least only you will see them Just wait till you get rock chips on the hood--- really puts a smile on your face
I have had mine for 4 yrs it has held up pretty well and there still isn't any others around town with the hood on there Ford as well which is really nice.
Joel
00 F350- intake,exhaust, pi convertor/ trans
00 F550- dump, intake,exhaust....TN BB exh coated, pi convertor/trans
01 F350- dump, intake,exhaust, BTS v/b, torque conv.
03 F250- CC SB- 5.4 gas
(2)- 06 Dodge 2500 CC 5.9 twins/trans/tunes/fuel
03 dodge drag 10.5 fuel only
jsf350 is offline
post #10 of 16 (permalink) Old 10-14-2007, 12:05 AM
OBS junkie
Cat_Rebel's Avatar
Re: cowl hood
Hasn't someone figgured out a way to get one on there without having that happen?
RIP Will Iott
