Axle Question... - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 14 (permalink) Old 10-09-2007, 04:25 AM Thread Starter
<<< THE GAUGE WHORE...
CSIPSD's Avatar
Axle Question...
The 2WD truck I am driving right now I think has a LS rear end, a few questions...
1. The 10.5 is on all superdutys correct? Whether 2WD or 4WD? (thinking axle swap)
2. What is easier, swaping axles or swaping the diff's???
This is all assuming the rear end is a 3.73 ratio...
Joe
CSIPSD is offline
post #2 of 14 (permalink) Old 10-09-2007, 04:39 AM
Starting Over
kainers's Avatar
Re: Axle Question...
all 10.5's as far as I know.
kainers is offline
post #3 of 14 (permalink) Old 10-09-2007, 12:37 PM
All done now
Arisley's Avatar
Except duallys.
Arisley is offline
post #4 of 14 (permalink) Old 10-09-2007, 04:34 PM
OBS junkie
Cat_Rebel's Avatar
Duallys had the Dana 80 like the Dodge or the old F450 (Superdutys).
I think you might just be better off swapping the axles. It's harder for us around here just due to the amount of rust we get on everything. Look for a tag on the the diff cover & look for 3.73 or 4.10 somewhere on it. If you can't find the tag just drive it, what are the RPMs in 4th gear (OD) going 55mph? A set of 3.73 will usually run 1600rpm or so. A set of 4.10s will run about 1900rpm or so.
97 F350 CCLB "Da Bus"
RIP Will Iott
"This ain't no practice run"
Cat_Rebel is offline
post #5 of 14 (permalink) Old 10-10-2007, 03:11 AM
Send a message via AIM to JohnT
If you have the tools, swapping the diff would be 10X easier IMO.
99 PSD 4x4 CCLB
05 PSD 4x2 RCLB
JohnT is offline
post #6 of 14 (permalink) Old 10-10-2007, 03:35 AM
Corona Killa
THEDIESELMAN's Avatar
Swapping the axle would be 100X easier and is as straight forward as it can get and you don't have to check backlash and gear mesh.
2007 DODGE 2500 CREW CAB 4X4 5.9 LITER CUMMINS
2002 FORD F-250 CREW CAB 4X4 POWERSTROKE
THEDIESELMAN is offline
post #7 of 14 (permalink) Old 10-10-2007, 06:52 AM
utah get me two
that diff isnt a dropout pumpkin,it would take a guy that knows rearends about 4-5 hrs to pull the old one and install and set tollerences,thats if you understand what you are doing....
[SIGPIC][/SIGPIC]2001 f250 4x4 cc sb 6 in lift...dp 6 pos..
glamis_dave is offline
post #8 of 14 (permalink) Old 10-10-2007, 04:39 PM
OBS junkie
Cat_Rebel's Avatar
Only tools needed for that are 1-2 extra guys, torches, impact wrench, 6 pack, jack, jack stands, spare axle & a few hours.
RIP Will Iott
post #9 of 14 (permalink) Old 10-11-2007, 03:58 AM
69W900A
69W900A's Avatar
It didn't take me 4 hours to setup my diff when I had my last one apart? There isn't any trick to setting up a diff, no black-majic. I'd just put a good LS in your housing. If you pull yours apart you can put a good LS in instead of the clutch type OEM you'd get by swapping an entire housing. Unless you want a clutch LS, some guys really like 'em.
69W900A is offline
post #10 of 14 (permalink) Old 10-11-2007, 04:21 AM Thread Starter
CSIPSD's Avatar
I can swap the 2wd for free...
Joe
CSIPSD is offline
