10.25 carrier and 10.5 carrier same? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 22 (permalink) Old 10-03-2007, 08:00 PM Thread Starter
Diesel Sled Head
zx800x's Avatar
I found a 10.25 detroit locker and want to install in my 2000 superduty. Is the carrier the same or will I need new ring and pinion for 10.25?
zx800x is offline
post #2 of 22 (permalink) Old 10-03-2007, 09:35 PM
Corona Killa
THEDIESELMAN's Avatar
Re: 10.25 carrier and 10.5 carrier same?
They are the same because that is what I did when I had mine installed.
2007 DODGE 2500 CREW CAB 4X4 5.9 LITER CUMMINS
2002 FORD F-250 CREW CAB 4X4 POWERSTROKE
THEDIESELMAN is offline
post #3 of 22 (permalink) Old 10-04-2007, 01:19 AM
Evil Genius
DCSpecial's Avatar
Yep, carrier is the same.
DCSpecial is offline
post #4 of 22 (permalink) Old 10-04-2007, 02:36 AM
Busy Busy
Marty's Avatar
sweet didn't know!
443.553.9234 - 410.392.3262
Elkton, Maryland
2005 F450 - Tow Bitch
Marty is offline
post #5 of 22 (permalink) Old 10-04-2007, 03:12 AM
OBS junkie
Cat_Rebel's Avatar
Okay here's a real question for you...will a diff cover off of a 10.5" fit on a 10.25" axle?
97 F350 CCLB "Da Bus"
RIP Will Iott
"This ain't no practice run"
Cat_Rebel is offline
post #6 of 22 (permalink) Old 10-04-2007, 05:05 PM
racehauler's Avatar
Yep, there has been a lot of people getting the finned aluminum rear cover for an 08 and it will fit all 10.5 and 10.25 axles.
Eric
96 F-350 CC Dually
300/100% B codes, Stealth dual pumps, H2E, BTS trans, ARP head studs, Comp 910 valve springs, Tyrant Tunes
6.0 IC, Fuelab electric fuel pump, NAPA 6637 air filter, ITP Overboost Annihilator, AeroTurbine 4040XL
racehauler is offline
post #7 of 22 (permalink) Old 10-04-2007, 06:43 PM
gregrob's Avatar
yes
gregrob is offline
post #8 of 22 (permalink) Old 10-04-2007, 09:34 PM
Corona Killa
Yes the only difference between the 10.25 and 10.5 is the ring gear size.
post #9 of 22 (permalink) Old 10-06-2007, 01:53 AM
Evil Genius
DCSpecial's Avatar
Ring gear size and inner pinion bearing size are the differences between the 10.5" and 10.25"
The inner pinion bearing is taller to make up for the 0.25" difference in ring gear diameter. Other than that, the housing is the same as are the rest of the internals.
post #10 of 22 (permalink) Old 10-06-2007, 05:05 AM
OBS junkie
Cat_Rebel's Avatar
I was asking because I thought of upgrading to the 08 dif cover too. Only cost my buddy $36 or so from the dealer. I ran over to a screw supply shop to pickup the longer bolts for it. It came out looking good which is why I thought of doing mine too...Thanks guys!
RIP Will Iott
