2" mini spring pack and 1.5" warrior shackle w/ 35s - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 09-27-2007, 03:37 PM Thread Starter
Banning Smut
PTSUPERD's Avatar
OK. I might run 35s instead of 33s. I would like to do it without having change a whole lot of suspension parts since I was able to get all the stock stuff to go back on my truck. My thought is to run a DR mini spring pack with a warrior shackle. Could I get away with running factory pitman arm and trackbar? I do have an adjustable fabtech trackbar I could use if I had to.
On the rear...thinkin' just a 5" block. Will i need to retain my carrier drop?
PTSUPERD is offline
post #2 of 2 (permalink) Old 09-30-2007, 02:19 PM
<- Sums it up
strokin_early_99's Avatar
Re: 2" mini spring pack and 1.5" warrior shackle w/ 35s
I would use 4" lift springs. But that is me.
35"'s rubbed the running boards and the fender liners, I was told that because of the 475lb bumper on the front of my truck. So I had to shift them back 3/4" of an inch. Plus I had to cut off a steel tab where two sheets of steel come together with a bolt, behind the fender liners. Then zip tie the fender liner, tight against the truck, to the body mount. Now I have little rub only when I don't turn hard and hit a big bump.
Early99 CC LWB 4X4
Updated B codes, Modded H2E, Big oil, half filled block, studded, John Wood 4R100. 232K miles
Tows like a champ!
"Damn Larry, he passed us like a freight train passing a hobo!"
--Lisa P.
Just sold to Larry
2-17-2019: 97 CC LWB 4X4 7.3 with full banks kit, John Wood E4OD. 139K miles
strokin_early_99 is offline
