Fog Lights - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 09-21-2007, 10:43 PM Thread Starter
Transfer Student from TDS
w4racing's Avatar
Fog Lights
Will oem fog lights work on my bumper? The truck came with a reunel front bumper when I bought it and when I sold it and part of the sell was the guys stock bumper. I want to put fog lights back on the truck and I cant figure out if they will work with the bumper. I see some trucks with and without them so I just confused to know if my will accept them. Here is a pic of my front end. Thanks for the help.
Early 99-F250 Quad Cab LB 4x4 - Banks 3.5" exhaust, fuel tank mods, Tricumulator Spings, Pyro Gauge, Banks Big Head, Tru-cool, AirDog.
w4racing is offline
post #2 of 12 (permalink) Old 09-21-2007, 10:53 PM
RDRCM
CooterBrown's Avatar
Re: Fog Lights
Yes they will.
#49
Sold
2006 Almighty CumminGs
CooterBrown is offline
post #3 of 12 (permalink) Old 09-21-2007, 11:14 PM Thread Starter
w4racing's Avatar
Re: Fog Lights
Very nice thanks for the quick response.
w4racing is offline
post #4 of 12 (permalink) Old 09-27-2007, 06:04 PM
Layson's Avatar
Re: Fog Lights
the only deal would be the wiring since yours would not have the wires for the lights...and the switch. You could just use a cheap fog light wire harness to hook them up...and also could buy a newer headlight switch to hook them up to. but you could just use a cheapo switch too..
Layson is offline
post #5 of 12 (permalink) Old 09-27-2007, 07:39 PM
Send a message via AIM to JohnT
Re: Fog Lights
I used a relay, since my truck didnt have the wiring for it either. Got a trigger off the parking lights. Worked well, until my bumper got tweaked and my foglight broke.
99 PSD 4x4 CCLB
05 PSD 4x2 RCLB
JohnT is offline
post #6 of 12 (permalink) Old 10-02-2007, 11:05 PM
txpsdcrwchf's Avatar
Send a message via Yahoo to txpsdcrwchf
Re: Fog Lights
if you get a wiring diagram you can find the wires for your lights, the switch should still be installed regardless of if your truck has them installed or not. try this.... turn your head lights on and then pull out on that same knob doing that will turn on your fog lights if installed correctly. Its put in that way so whenever you turn off your head lights the fog lights go off as well.
also just because your truck didnt come with them installed doesnt mean the plugs (into the wiring harness) are not there. you may have to buy a harness to get to the plug from the back of the fog light.
for instance all super duty trucks are wired for cab lights but not all have them. the plug for them is located behind the passenger kick panel just below the glove box.... and like i said the switch is the same switch thats used in trucks without them installed.
Jeff
HIS: EARLY '99 F250 SD 4x4 Off Road, 7.3L PSD 6 SPD SuperCab Short Bed
DP Tuned (F5) NS, S, 40T, 80E,
HPx Line-DIY Tymar-Fuel System(on Return)
HERS: '99 DODGE Ram 2500 4x4 5.9l I6 Cummins 6SPD QuadCab Shortbed
Edge ez 20, 40, 60:
txpsdcrwchf is offline
post #7 of 12 (permalink) Old 10-05-2007, 07:12 PM
Layson's Avatar
Re: Fog Lights
I don't think the switches for the 99 work with fog lights... it may beable to pull out but I don't think there is anything to hook it up too..
do yours work with fog lights??
I think 2000 or 2001 was the first year they were installed with the wire harness. ??
Layson is offline
post #8 of 12 (permalink) Old 10-05-2007, 07:54 PM
OBS junkie
Cat_Rebel's Avatar
Re: Fog Lights
I'm pretty sure 01 was the first year they started the factory fog lights. Haven't seen any 99 or 00 Superdutys with em.
97 F350 CCLB "Da Bus"
RIP Will Iott
"This ain't no practice run"
Cat_Rebel is offline
post #9 of 12 (permalink) Old 10-05-2007, 08:09 PM
Re: Fog Lights
my 01 has them. my geuss is you can get a switch from an 01 and use that switch. all you would need to do is find out which pin is the signal wire for the fog lights, then go form there. you can get switches from ebay pretty cheap.
PMRCM#1
slowleak is offline
post #10 of 12 (permalink) Old 10-05-2007, 08:16 PM
Re: Fog Lights
try these
PMRCM#1
slowleak is offline
