Kool-Vue tow mirrors - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 03-07-2012, 01:11 AM Thread Starter
Anyone that has these mirrors in power, do they work correctly? I have a set on an E99 with the correct plug and they don't seem to move in or out, just up or down. I changed the switch and no change.
E99 (8/98) CCLB 4x4, 6" Skyjacker Lift, 35's on stock rims, Tymar intake, 4" downpipe-5" Custom exhaust, PHP Phoenix 6-Pos. Chip
machete31 is offline
post #2 of 8 (permalink) Old 03-07-2012, 04:23 AM
Intelligent Burro
Re: Kool-Vue tow mirrors
I put a set on my e99 a while back. I dont recall having to do anything special to get them to work. If I remember right they came with an adapter and then I had to run an extra wire for the heat but, my truck did not have heat originally.
E99, F250, 7.3, CCLWB, Auto, manual 4x4, AIS intake, AD injectors, PHP FU, AIC, 3:73 gears. Autometer Gauges - (EGT, Trans Temp, Boost), Edge CTS
Dieselpop is offline
post #3 of 8 (permalink) Old 03-09-2012, 06:26 PM Thread Starter
They work, or should I say the have power to them, just don't seem to move the way I'm directing them to via the switch.
post #4 of 8 (permalink) Old 03-09-2012, 08:56 PM
BigKid's Avatar
Are they 08 mirrors on an older truck?
2011 Cadi CTS-V
2013 F250 ECLB 6.7 2wd
2013 Platinum, SPE tuned
BigKid is offline
post #5 of 8 (permalink) Old 03-09-2012, 09:03 PM
so many trees
sargepep56's Avatar
i have em. they work fine for me.
some stock truck from washington state
sargepep56 is offline
post #6 of 8 (permalink) Old 03-11-2012, 04:27 PM Thread Starter
No, plain ole Kool-Vue's for 99-04 with power only.
Maybe I got a bad set.
post #7 of 8 (permalink) Old 03-11-2012, 06:15 PM
I like turtles
NE-STROKE's Avatar
I have had really good luck with Kool-vues.
08 duramax ccsb efi live, air dog 2, isspros, 5 inch exhaust and some other cool things. 2001 duramax 2wd (Project truck)
Once had a signature that had some bad ass stuff on it. Now its back to crap.
NE-STROKE is offline
post #8 of 8 (permalink) Old 08-10-2012, 09:42 AM
HonaDavis's Avatar
Anyone that has these kool-vue car parts mirror in power, do they work correctly? I have a set on an E99 with the correct plug and they
Kool Vue car parts products have good reviews and feedbacks from consumers. What I know is that they provide a manual for proper installation of the products they manufactured. Or maybe you could ask one from your dealer mate. But you should ask if it fits or is the exact match for your vehicle make, model, and year. You should follow proper installation. Roll down your window and shut your vehicle off. You must also disconnect the battery's negative cable. Remove the interior door and the corner trim before lifting the door panel. unplug the wiring harness if it is not manual. Seperate the actual mirror from the assembly. Attach the mirror by snapping it at the backing with the tabs at the mirror assembly. then reverse the previous steps.
HonaDavis is offline
