6.4 Track Bar removal? Urgent - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 17 (permalink) Old 02-19-2012, 11:19 PM Thread Starter
dstryr's Avatar
Anyone have any tips on how you remove the bar from the axle mount? I cant seem to break it loose...
dstryr is offline
post #2 of 17 (permalink) Old 02-20-2012, 01:13 AM
STILL LEARNING
Bradbilt's Avatar
Re: 6.4 Track Bar removal? Urgent
They are torqued to 250ft/lbs + and are lock tighted
Bradbilt is offline
post #3 of 17 (permalink) Old 02-22-2012, 02:38 PM
one2nine's Avatar
brass hammer and sometimes a tie rod fork may help. Mine was on tight as hell.
2010 F250 CCSB - 73mm atmo, II pump, 60% nozzles, no limits intake, etc - sold
one2nine is offline
post #4 of 17 (permalink) Old 02-22-2012, 05:50 PM
3/4" breaker bar and a cheater.
2012 F-150 XLT Ecoboost SuperCrew 6.5' 4x4
cartmanea is offline
post #5 of 17 (permalink) Old 02-22-2012, 08:31 PM
Faster Than You
Eric@PTP's Avatar
Your going to need at least a 1/2" drive breaker bar and a cheater pipe for leverage.
post #6 of 17 (permalink) Old 02-22-2012, 08:33 PM
If you use a 1/2" bar, make sure it's a brand with lifetime warranty. :)
post #7 of 17 (permalink) Old 02-22-2012, 08:34 PM
Faster Than You
Eric@PTP's Avatar
Ive done it plenty of times with a 1/2" but its a snap on, most 1/2" bars are good to 250-275 ft lbs. Any thing beyond that you have to step up to a 3/4" bar.
post #8 of 17 (permalink) Old 02-23-2012, 03:34 AM
wedge a big bar between the axle and the track bar, then lower the truck. and it should help you thats how i got mine off
Nascar_fan28 is offline
post #9 of 17 (permalink) Old 02-24-2012, 06:59 PM
Breaker bar and hydraulic jack. Not a bottle jack.
You'll want to use a 12 point socket so you can turn it just one notch or so, since there won't be much room to work with under there.
Worked for me.
Will
2001 F250 CCSB, Lariat, 4x4, 7.3 PSD, 4R100.
wsigo is offline
post #10 of 17 (permalink) Old 02-24-2012, 09:05 PM
07_powerstroke's Avatar
You guys do it the hard way!
One of the best tools I have bought on my truck.
07 ford f250
Josh Vandyke
07_powerstroke is offline
