35" tires with spacer on a level pics...? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 23 (permalink) Old 02-19-2012, 03:20 PM Thread Starter
I have 3" level kit front, 350 blocks in rear, and 35s on stock wheels...so they are not that wide (375/75/16)
Tires are still nice and crispy still so I'm not ready to do a wheel and tire combo yet..I'm also flipping back and forth about lifting 6"...for now I'm thinking of some 1.5" or 2" wheel spacers to slightly change the look..anyone have any pics of spaced put wheels or somehting similar?
This is how it sits now..would also like to do 08 mirrors, tailgate and bumper.
ps3 online: kennyfcknpowers
tturbonegro is offline
post #2 of 23 (permalink) Old 02-19-2012, 03:33 PM
Administrator
Zmann's Avatar
Re: 35" tires with spacer on a level pics...?
good spacers are crazy money and not the best solution
you would be better off doing the rims and tires in the size and offset you desire
IMHO
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #3 of 23 (permalink) Old 02-19-2012, 03:35 PM Thread Starter
What's crazy money and why do you say that?
post #4 of 23 (permalink) Old 02-19-2012, 03:35 PM
Newbie
tbsimmons's Avatar
If you want to research spacers look up Hub-Centric Spacers. They would be the best on something this heavy, which I still would not recommend. The other is lug-centric which are cheaper but I would not try them.
2008 F450 4x4
Stock
tbsimmons is offline
post #5 of 23 (permalink) Old 02-19-2012, 08:02 PM
Administrator
Zmann's Avatar
1 set of steel
2 Wheel Spacers Steel near new - PowerStrokeNation : Ford Powerstroke Diesel Forum
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #6 of 23 (permalink) Old 02-19-2012, 11:03 PM
Northshore Powerstrokes
NorthShoreDiesel's Avatar
I was running 2" hub centric spacers on my 08 F350 for the front end to make the 19.5 even with my F450 flares, but the studs keep busting and they were ford oem studs on the steel spacer. I spent $600 on the spacers and another $320 on studs. Then I said forget it im not running no damn spacers no more after my tire almost flew off on the freeway, it was held on by one stud and nut. I wouldn't run spacers well maybe its because the F350 so dang heavy I can see them maybe working on a F250. If not my best bet would be to go for the wider rim and off set to be safe. Then again that's just me do what ever you think is right its your truck :)
99 F250 7.3 SHORTBED 4X4, XLT MODS-DP TUNER K&N AIR FILTER, 4" MBRP STRAIGHT PIPE 5", 08 F350 6.4 SHORTBED 4X4, XLT MODS-SPARTAN, AFE FILTER, 4" MBRP STRAIGHT PIPE 5", 03/5 F350 6.0 SHORTBED 4X4 LARIAT, XLT MODS- AFE, SCT, 4" MBRP
NorthShoreDiesel is offline
post #7 of 23 (permalink) Old 02-20-2012, 12:53 AM
bryced1's Avatar
yah, i wouldnt run spacers. Im not sure what kind of rims you like, but you can get the M/T classic II style made by procomp for around $600 brand new shipped. plus look around on your local craigslist, there are always 8 on 170 rims on there around my area. Might luck out. even if you find a set you like with tires on it you can always pull those off and sell them.
On a side note, how do you like those duratracs? Im thinking of getting a set sometime soon.
bryced1 is offline
post #8 of 23 (permalink) Old 02-20-2012, 04:12 PM
Administrator
Zmann's Avatar
f250 vs 350 isn't a huge weigh difference even between SRW DRW
say a 2008
" F250 4x4 srw 7085lbs
" F350" " " " " 7223lbs
" F350 " " DRW 7910lbs
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #9 of 23 (permalink) Old 02-20-2012, 05:30 PM
Ian123's Avatar
Lots of guys are into that look where I live and none of them have had trouble that I know of...not sure what kind of spacers they are running but there are definitely good ones out there
2007 F-250 CCLB Lariat FX4 6.0L
Originally Posted by fuekear View Post
I just blow my heads off the block once a year. Keeps nice clean antifreeze in it, although not that cost effective it sure is fun.
Ian123 is offline
post #10 of 23 (permalink) Old 02-20-2012, 06:42 PM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
I think it looks great the way it sits... Keep the tires tucked in nice and neat.
Joe
CSIPSD is offline
