Drive Shaft Advice - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 02-14-2012, 08:52 PM Thread Starter
Drive Shaft Advice
I have decided to get a new drive shaft. I have narrowed it down to two options. 1. A two-piece CV shaft from High Angle Driveline. 2. A one-piece 5 inch diameter aluminum shaft from CCI Ford Super Duty Monster 5 Aluminum Drive Shaft Upgrade - CCIDriveline.com and eliminate the carrier bearing. The truck is a crewcab shortbed with 5.5 inches of lift, but I may go to 7 inches later. Anybody have any experience with either shaft?
Iron is offline
post #2 of 5 (permalink) Old 02-14-2012, 09:09 PM
PowerstrokN805's Avatar
Send a message via AIM to PowerstrokN805
Re: Drive Shaft Advice
not with buying a new shaft . but when i put a 10in lift on my truck it would vibrate bad at high speeds. so i took a angle finder an made sure that the angle of the shaft coming out the trans was the same as the angle going to the rear end. by placing a spacer under the u joint in the center of the 2 piece stock shaft./ to drop it down a little! an my vibration went away! hope this helps!
1999.5 F-250 Crew Cab Short bed 4x4
Superchips Cortex, K&N Air filter, 4inch MBRP exhaust, and 7inch lift.
PowerstrokN805 is offline
post #3 of 5 (permalink) Old 02-14-2012, 09:28 PM
ToMang07's Avatar
No experience.... But I really like the looks and idea of a solid 1-piece drive shaft. I would like to replace mine with a one piece, some day.
~Tom~ 02 F350 CCSB 4x4 SRW 7.3L, DIY-6637, PHP Phoenix-(STK-80dd-100P-120R-65T-40T) 4" TB-409SS MBRP, GS 3 in 1, EGT/Boost/Tranny, Fisher 8' MM2. Tymar HPX, NON-EBV Pedestal, Turbo Master, Wicked Wheel, Hutch/Harpoon, RR-Plenums/clamps, 203*TS and Billet Housing, ELC, Fumoto, CCV Dumped, Foil, AIH, and EBV, Pontoons All Missing...~AE w/Ford Pack~
ToMang07 is offline
post #4 of 5 (permalink) Old 02-14-2012, 09:33 PM
Ian123's Avatar
I would go with the one-piece. Looks better and you don't have to deal with shimming the carrier bearing
2007 F-250 CCLB Lariat FX4 6.0L
Originally Posted by fuekear View Post
I just blow my heads off the block once a year. Keeps nice clean antifreeze in it, although not that cost effective it sure is fun.
Ian123 is offline
post #5 of 5 (permalink) Old 02-17-2012, 01:16 PM
Just eliminating the drive shaft bearing will not solve the problem if your flange angles are wrong.
lenzhotrod is offline
