08 wheel offsets? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 02-08-2012, 12:32 PM Thread Starter
I FINALLY JUMPED!
desertwheeler's Avatar
08 wheel offsets?
So what's a good offset for my 08 to run with a leveling kit and 35's that won't rub anywhere and possibly 37's on a 4.5 inch lift? The wheels I am looking at only come in 0 offset 5 inch back spacing for an 18x9. I think that the stock 18s are 6 inch back spacing? Do I need something with a more positive offset? Thanks
08 CC SB 4x4
HID's, N-FAB prerunner bar 3 HID's, N-FAB steps
2.5" Icon lift, 35's, 55 gal aero tank, S&B intake
H&S tuned, Nothin special.....
desertwheeler is offline
post #2 of 3 (permalink) Old 02-08-2012, 08:38 PM
Re: 08 wheel offsets?
Stock offset is +40 or +44mm. If you look at backspace, you also need the wheel width to determine where the tire will be positioned. 0 Offset will move the wheel and tire center out about 1.75" from stock. That will stick out past the fender about 1-1.25" with a 12.5" wide tire. To clear the radius arms and not stick out too far with a 35x12.50 you want something in the +10 to +20mm range I believe. For a 37" to not rub the radius arms you're pushed out to around zero offset.
2012 F-150 XLT Ecoboost SuperCrew 6.5' 4x4
cartmanea is offline
post #3 of 3 (permalink) Old 02-09-2012, 03:49 AM Thread Starter
I FINALLY JUMPED!
Alright thanks!
08 CC SB 4x4
