Overdrive button not working! - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 02-07-2012, 06:29 PM Thread Starter
Gbdjunior's Avatar
My overdrive button hasn't worked since the day I got it but didn't care because I never pull anything. Well the shift lever is also loose, I can moved it about 3/4" while in drive. I called the ford stealership and they said it could be the arm its self or a piece of metal in inside. Anyone done this before and have advice about it, before i got taking stuff apart? Thx
02 CCLB 4x4, 2011 mirrors, Leveled, AEM Intake, 4" TB MBRP SS straight pipe, DP tuner - 60 tow, 80 eco, 120 race, Foil Delete, Zoodad Mod, banks bighead wastegate acuator, warn hub locks, 6 leaker 26 trans cooler, 308K and counting.
Gbdjunior is offline
post #2 of 7 (permalink) Old 02-07-2012, 06:56 PM
95powersmoker's Avatar
Re: Overdrive button not working!
The arm is easy. If i remember correctly there are two screws that need to be tightened up... The od button is also easy, take the steering column cover off and make sure the wires are not severed or unplugged.
James
2000 F350 CCLB 4x4 auto, 250/200's from PIS, No Limit tunes, Isspro gauges, 4" exhaust and intake.
95powersmoker is offline
post #3 of 7 (permalink) Old 02-07-2012, 07:03 PM
Bmiller5's Avatar
Mine has been flashing randomly lately? What's that mean?
Bmiller5 is offline
post #4 of 7 (permalink) Old 02-07-2012, 07:44 PM Thread Starter
Gbdjunior's Avatar
Thanks but i got aintsy and found the wires had been cut. thx
post #5 of 7 (permalink) Old 02-07-2012, 09:54 PM
Usually means a code has been stored, could be a sensor having an issue...
James
post #6 of 7 (permalink) Old 02-10-2012, 02:05 AM
could be the sensor in the rearend also
hcwt is offline
post #7 of 7 (permalink) Old 02-13-2012, 08:11 PM Thread Starter
Gbdjunior's Avatar
Put new arm in from ford, works great now.
