up-pipes question - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 01-21-2012, 10:37 PM Thread Starter
up-pipes question
i just replaced the up-pipes on my e99 truck as they were leaking and could smell exhaust in the cab i used beans brass donuts and the smell was gone for 2 days and now its back. they must be leaking again but is there any other places they are common to leak. i will look tomorrow at the up-pipes again but i wouldnt think they would be leaking again after what i just did.
99oilburner is offline
post #2 of 6 (permalink) Old 01-22-2012, 12:44 AM
Horsepower Enthusiast
sho669's Avatar
Re: up-pipes question
Back ports on the exhaust manifolds are the other common place I see them leak.
03 CCSB King Ranch 4X4 6.0, IDP Xstreet, Muffler delete. [email protected]
00 CCSB, ZF6, 2WD. RIP 1-22-12
06 Mitsubishi Evolution IX SSL, LR 2.0, TS EFR9180, E85, 4 slicks and a chute...maybe some other stuff
69 Camaro, awaiting turbo LSX and chassis work
sho669 is offline
post #3 of 6 (permalink) Old 01-22-2012, 02:11 AM Thread Starter
did manifold gaskets last year not leaking there.
post #4 of 6 (permalink) Old 01-22-2012, 02:29 AM
< pissed off pumkin.
skylinedan's Avatar
Talking Re: up-pipes question
Might want to fix the hole in you cab too while your at it. Mine leaked and I never smelled a thing when I was driving it. A hole in your fire wall is a bad thing. if you have a fire under the hood for some reason that hole just became a door for it to get in side, and the whole thing will go up a lot faster.
Dan
2003 F-350 4x4, Ext cab. 7.3 AFE stage II 4" turbo back exhaust, garret GTP 38, 1.15 van turbine housing,EBPV deleated, non waste gated, ATS compresor housing, WW II, bellowed up pipes, CFM + spyder conversion, Hydra chip with Bill's tunes, CCV mod, Hutched, harpooned, RR fuel system, 6.0 trans cooler, Swamps IDM, HPX.
skylinedan is offline
post #5 of 6 (permalink) Old 01-22-2012, 03:33 AM
Hood Rich
CTC DEEZUL's Avatar
Send a message via AIM to CTC DEEZUL
dont you have to re-torque them after a heat cycle or two?
i skipped the whole process and went with one piece.. not sure if avail for e99 though
NWI Coal Rollers Association
Local 444- Rolling Coal Teamsters
via Beans Toonz
DI SS Up-Pipe
GTP38R
CTC DEEZUL is offline
post #6 of 6 (permalink) Old 01-22-2012, 09:00 PM Thread Starter
i did re-torque them today got a turn or 2 out of them but i did find i hole in the firewall looks like the hole for the clutch pedal someone took the plug out of there to run wires at one time and mine is a auto truck so looks like i have to go to the dealer tomorrow to try and get the plug for there.
