air down question - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 01-06-2012, 07:09 AM Thread Starter
is awesome
Cool air down question
Hey guys I was wondering if its possible to air down my 35x12.5 toyos on my 20x12 XD diesels without popping the bead. Im planning on going to Pismo dunes in a couple of weeks and plan on just crusing around on the dunes just a little but mostly we will be rideing quads.
05 F250
6" fabtech/pro comp es9000
es2000 dual steering stablizers
20x12 XD diesels 35x12.5/20 Toyo MT
Banks ram air/cat back exhaust
Edge Juice platinum
Zoodad, more mods to come......
westcoast is offline
post #2 of 7 (permalink) Old 01-06-2012, 01:15 PM
Wish_It_Was_A_Bowtie2004's Avatar
Re: air down question
We air down my buddies to around 10 psi at Silver Lake sand dunes in Michigan and he's got 20's. His trucks only a 1/2 ton though. But he is running stock tires. We hammered the s#!t out of his truck and never had a problem with rolling the tires off the bead or damaging the tires or rims. You should be fine with the extra meat you're running. I would start at 18 psi and go from there.
2004 F-350 CC/SB 4" downpipe and exhaust and thats it 220,000 miles strong
2002 F-350 CC/LB AFE Cold air, 4" turbo back, Rosewood Stage 2 Sticks and supporting chip. 4" lift on 35s. 150,000 miles strong
Just another Duramax guy seeing what the competition is raving about.
Wish_It_Was_A_Bowtie2004 is offline
post #3 of 7 (permalink) Old 01-06-2012, 05:48 PM
Ian123's Avatar
I think it will be fine just don't go too low. Maybe 15 or 20 psi. I have some 20x14's sitting in my garage that I plan on mounting on 33x12.50's and I'm afraid to air those down at all lol. But I think on a 20x12 you should be ok
2007 F-250 CCLB Lariat FX4 6.0L
Originally Posted by fuekear View Post
I just blow my heads off the block once a year. Keeps nice clean antifreeze in it, although not that cost effective it sure is fun.
Ian123 is offline
post #4 of 7 (permalink) Old 01-07-2012, 06:36 AM
1sd
1sd's Avatar
I ran my 37 13.50 20's at 15 psi 157 miles across the Mojave Desert last year with no problems.
Steel Gray, 2006 SD CC, XLT Lariat, 8" Fabtec lift on 37/14.50x20 Falken Wild Peaks. 20x10.5 Moto Metals. Quad Fox Shox Reservior on all corner, 4.56 ring and pinions, Baja Designs 8" Sol Tec lights, Amp Research electric steps. Kenwood head unit, Yeasu FT8800 tri-band ham, Lowrance Elite 5M GPS. Snug Lid bed cover with Bed Rug liner.
1sd is offline
post #5 of 7 (permalink) Old 01-07-2012, 12:42 PM
Newbie
tbsimmons's Avatar
Depends on how you are going to drive the truck. If it is going to just be used to pull on and off the beach then you can go lower. If you are going to be running the truck in the dunes you will want more.
When I had Toyos Muds in 35's I would air the front down to around 15 and the back to 10-12 with no weight in the back and it did fine. If you have weight in the back then you will want more.
2008 F450 4x4
Stock
tbsimmons is offline
post #6 of 7 (permalink) Old 01-07-2012, 02:12 PM
King Dingaling
TANK'S 250's Avatar
airing down is a tricky thing....
You can run 10psi all day long....as long as you don't take any hard and fast turns(over 15mph)
....for a good "all around" psi....I would stay around 15-20psi
TANK'S 250 is offline
post #7 of 7 (permalink) Old 01-08-2012, 05:03 AM Thread Starter
is awesome
thanks guys Ill def try 20psi since I will be towing a small trailer with 4 quads and I do plan on going up and down the dunes a little and going down the sand highway I'll only see speeds up to about 30-35 like a said just crusieing up and down the dunes. Any real stuff we will be doing it on the quads. My main concern is poping the bead since I have 12.5 wide tires on 20x12 wheels
05 F250
Edge Juice platinum
