Discuss these pictures. - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 14 (permalink) Old 12-29-2011, 11:04 PM Thread Starter
Ok well was doing a tire rotation today and I came up with some pictures I would like to get more info about. Please reference what picture you're talking about when you respond.
This picture is of the drivers side frame infront of the tire but back from the bumper bracket. There is a bolt with a captured nut there. Well what goes here? Does anyone have something attached there is so what?
This is the drivers side, bottom of the radiator, kinda where it mounts i think. Well there is coolant dripping out of it. Nothing drastic but i notice a wetspot everynow and then on the ground. What is it and where is it coming from?
With discussion of trac bar issues here is a picture of mine. This is a 6" 4link lit with a 2" leveling kit. This is with a trac bar drop bracket and a drop pitman arm. Should i change something or ok how it is?
I think this is the axle seal? Is it a common problem for these to come loose? Should i be worried or just not worry till i take a hub off for something. Or is there a way to put it back in with the hub on?
And to top it off Just look
2006
F350, 6.0, CC, SWB, VEGISTROKE, AD2, ARP's, OEM Gaskets, Pmax, 200cc Sticks SCT SF3, FICM Tunning, Custom ZOODAD, Coolant Filter, EGR Delete, Smoked Cab Lights, 6" Mitre Stacks, 8" 4-link Lift, SS-M16 37/13.50/20 SURE WAS NICE WITHOUT THE ADS
YoungMT Hick is offline
post #2 of 14 (permalink) Old 12-29-2011, 11:14 PM
COMPUTER BLUE
airfish2011's Avatar
Re: Discuss these pictures.
and i thought i had some loose ends to fix on my truck
ouch
lots of 6.4's and a few 6.0's
airfish2011 is offline
post #3 of 14 (permalink) Old 12-30-2011, 01:01 AM
Oooo, White Lightning !
Dieselboy's Avatar
Old girls taken a beating.
You could have a small hole in your rad. Try running some barnsleak through it.
Trac bar looks fine. Im not sure why you are asking ?
As for that bolt, if memory serves correct it has just come loose. I wanna say it bolts into the trac bar bracket or pitman arm bracket. Just tighten it back in.
Leaf springs do break btw, just take it out and take it to a spring shop and have them put a new one in. Id recommend both sides just so they sit and wear evenly.
Race truck
2002 F-350XL RC/LB
NADP Race Trans/PCS'd
Lowered w/ traction bars
Unlimited 450/400s
S475 on Irates mount
TE 17* with Gen3
DI Headers
Dieselboy fuel system
[email protected]
599.3 on BDs dyno
Tow pig
2000 F-250XLT EC/SB
Tuned
Exhaust
Intake
Dieselboy is offline
post #4 of 14 (permalink) Old 12-30-2011, 01:03 AM
Learning from PSN
Diesel X's Avatar
In the picture with the axle seal ,is it the drivers side? If so I would change it when you get a chance. Mine and a friend's late 99 were bad and both of our inner axle seals were bad. The driver's side short tube seems to allow water and dirt in easier and eats the inner seal. The inner seal isn't too bad to replace, but if you catch it early, it is one less thing to do. We made a tool out of all thread rod and some steel plate to install the inner seal.That really helped to make it easier. I'm no expert just going by prior experience. I would replace both sides of the springs also ,if one is broke the other is weak and will also break sooner then later. Found that out from experience also.
94.5 CCLB 5 speed broke again
E99 CCLB 4x4 6 speed MBRP 4" straight turbo back 6637 6" lift Southbend way too small Nitto 265 tires a.k.a Grugly 04 Excursion Limited
Diesel X is offline
post #5 of 14 (permalink) Old 12-30-2011, 01:28 AM Thread Starter
Ya just a few things i have seen that need attention.
Radiator - Putting something in the coolant beside cat elc i think would clog up the oil cooler. and would also just clog the coolant filter so i dont know how that would work?
As for the bolt. has nothing to do with the trac bar nor the pitman arm. It is a bolt that goes through the frame into a captured nut. If i tightened it it would do nothing but hold that section of frame together. Not a bad idea to prevent rust i guess but ya nothing to do with the trac bar or pitman arm or their brackets.
As for the trac bar pic - I was wondering if getting the two more parallel would prevent bump steer or if they are fine the way they are. Thread have been started regarding flipping the trac bar or getting an adjustable one to make the drag link and trac bar more even so i was wondering about mine.
And the springs yes i am still working with the manufacturer. I will bring up the idea about replacing both due to the eneven ride hight or sagging/aging of the springs at different times. They have a lifetime warranty on defects so i hope to get this replaced.
Axle seal is the drivers side. Passenger side looks ok. I will tackle it i guess whenever i take a hub off. I have seen the custom (redneck) homemade presses people make to seat these seals. Is it as simple as beating them in till they sit? IDK i have never done it.
2006
post #6 of 14 (permalink) Old 12-30-2011, 01:28 AM
Lost Cause
Betaracer's Avatar
I'll make comment on the rear leafs. Replace the entire pack with either Deaver or Icons. It is going to cost some money to pull the packs out, replace the broken leaf and the corresponding one on the other side, and still have the risk of another or more in the pack failing. Get some 5" lift springs and add a small block if needed to get the desired stance.
2016 F-350, FX4, CCLB, 6.7PSD, 7" OUO/ICON/FOX lift, 38x13.50-18 Toyo MT
Betaracer is offline
post #7 of 14 (permalink) Old 12-30-2011, 01:40 AM
Learning from PSN
Diesel X's Avatar
You might be able to beat them in. There is not alot of room in there . A home made tool will more then likely seat them in better.
Diesel X is offline
post #8 of 14 (permalink) Old 12-30-2011, 02:44 AM Thread Starter
Springs - There is a lifetime warranty so i hope to get a new set from the Manufacturer and hopefully in the 8" version and not 6". Well then i will just have to lift the front then huh :)
Seal - Ya i will try and fit it in. Question is where does it go? Does it ride on the collar on the stub shaft or does it go behind there?
2006
post #9 of 14 (permalink) Old 12-30-2011, 09:40 AM
Learning from PSN
Diesel X's Avatar
The outer seal rides on the stub shaft. No problem getting it on. Just tap it down till it seats on the lip. The inner seats into the inside of the houseing. You have to take out the center section. Don't worry about that. It comes out in one piece. Just make sure you don't mix up the bearing caps. They are marked which way is up. Make sure you have a good torque wrench and a repair manual to get all your torque values. You might luck out and not have a bad inner seal.
Diesel X is offline
post #10 of 14 (permalink) Old 12-30-2011, 12:53 PM
Administrator
Zmann's Avatar
Yes it does but and you might be able to just work it back on without taken anything apart but
that is the dust seal not to be confused with the seal in the knuckle they have a new improved dust seal that replaces the axle shaft mounted one for an axle tube inserted one that actually works,, but to get to that is way more than "taking a hub off" the above comment about bearing caps and what not does not apply to these trucks ,, they use a unit bearing
if you have bump steer fixing the angles should help
new seal in the tube and you can see where the old seal used to sit on the axle
as far as the bolt and captured nut I would bet your missing a skid plate? I will go look at mine later
can't really tell location from the pic but make sure your radiator petcock is closed all the way
DTR's Donation page
RIP DTR Ron
Zmann is offline
