Wiring guages - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 12-21-2011, 12:35 PM Thread Starter
OSCS's Avatar
Wiring guages
I'm putting in some glow shift guages and wondering what you guys are using for the switchable power source? I can't use the running lights switch Becuase it has a dimmer and screws with the glow shifts.
542RWHP "E99" True 5" exhuast system/910's/arp head studs/t-500/RR with fuel system/SB pushrods/gated S366 turbo/250-100/HPX/cutom intake/ DI 6 point/ gear head tunes/BTS
OSCS is offline
post #2 of 3 (permalink) Old 12-21-2011, 12:54 PM
'05 Excursion
Term3's Avatar
I tied into a hot in run and start wire coming out the back of the fuse box. Easy to pin point if you have a meter. What year is your truck I may have the electrical diagram?
Term3 is offline
post #3 of 3 (permalink) Old 12-21-2011, 12:56 PM Thread Starter
OSCS's Avatar
Re: Wiring guages
E99
OSCS is offline
