Stock height coil spring swap on 2011 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 12-21-2011, 12:36 AM Thread Starter
bandit67's Avatar
I'm planning on getting rid of my CA code 6000# front coil springs that came with the Snow Plow Prep Pkg (didn't need it, just happened to be on the truck I got) on my 2011 F250 Crew Cab Long Bed 4x4. Springs are way too stiff on our concrete highways, and the truck bounces horribly, even with 2000 lbs in the bed.
Looks like the standard Crew Cab Long Bed front coils are the DA code 5600# springs. The next step down is the EA code 5200# springs, which I think may be standard on the Crew Cab Short Bed.
I'm thinking that I may go with the 5200# springs because I'm not sure the step down to the 5600# will make enough of a difference.
Also, not exactly sure if the spring rating is per spring or per pair - parts guy at dealer was thinking it was per spring. Decision on which spring to go with will probably relate to the total spring rating difference for the pair.
Thoughts / opinions?
2011 6.7L Lariat CC LB 4x4. Elec. locking 3.55, 10,000 GVWR pkg, 5th wheel hitch prep pkg, tailgate step (handle delete), ARE TW series topper, Line-X
In service 12/15/2010
Previous: 2001 F250 7.3L Crew Cab Long Bed 4x4, BTS, Garrett BB turbo, DP Tuner F6
Ford Vehicle Sales
bandit67 is offline
post #2 of 2 (permalink) Old 12-24-2011, 04:20 PM
Twan's Avatar
Re: Stock height coil spring swap on 2011
I would think that weight is pair, the truck is only rated for 6000lbs, I would go with the 5200, the softer the better.
2006 CCLB 4x4 King Ranch 2"lift 35's, S&B, sct tunes by Innovative, Quick Tricks, Powermax, 6.4 Banjo bolts, coolant filter, edge insight, 4" turbo back.
Twan is offline
