auto scan gauge II - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 05-18-2011, 02:21 AM Thread Starter
Ouch's Avatar
Send a message via Yahoo to Ouch
auto scan gauge II
Anyone have expierence with the Linear Logic Auto Scan Gauge II? I seen the thread in the 6.0 section just wondering with the 7.3 guys.. I picked one up, havnt got around to playing with it yet..
Ouch is offline
post #2 of 9 (permalink) Old 05-18-2011, 02:23 AM
bluedge8's Avatar
Re: auto scan gauge II
where'd you get it from
1997 f250 4x4 sclb, auto, 3.55's, 191k, diy intake w 6637, ccv mod, pyro, boost, trans gauges, 3" dp to 4" single exh. super chips for now. scangauge
Originally Posted by jdc753 View Post
Besides there is absolutely no way to idiot proof something, since they are always coming out with better idiots by the day
bluedge8 is offline
post #3 of 9 (permalink) Old 05-18-2011, 04:20 AM
tbolt's Avatar
I bought the Aeroforce scanguage 2 1/16 guage mounted on my column. monitors everything, reads codes, clears codes and will run a buzz test as well as a cct. You can also set warning lights on different parameters. Got it from Joey @ Term. I love this thing!! Reasonable price also.
Glen
early99 f350 cc, lb, 2wd, drw, A pillar autometer guages, CTS monitor, AIS intake, 4" turbo back cat delete diamondeye exhaust, dptuner, pmt1, jw vb, Swamps ab inj, Adrenaline oil, Coolingmist, 180*T, Trucool cooler, spin on trans filter, Firestone air bags, 2" frt leveling kit, now chased by a 34' toyhauler
tbolt is offline
post #4 of 9 (permalink) Old 05-18-2011, 11:18 AM Thread Starter
Ouch's Avatar
I got it at camping world up in Rogers...
Ouch is offline
post #5 of 9 (permalink) Old 05-18-2011, 12:09 PM
bluedge8's Avatar
hmm, didn't know they sold that kind of thing. did you try it out?, otherwise there is a scangauge in classifieds for sale.
bluedge8 is offline
post #6 of 9 (permalink) Old 05-18-2011, 12:37 PM
CGMKCM's Avatar
I have one on my VW TDI and it works great. The mileage is very accurate after you get things dialed in.
I have used it on my PSD and it works for most readings, but has some quirks. For example the water temp always shows the same temp, and it is way out of the normal range.
There are a few guys on here using it and have figured out how to get more out of the gauge.
[SIGPIC][/SIGPIC]
2001 F-550 4X4 Lariat
BTS Tranny
PHP Phoenix chip
H2E Turbo With WW II
Adrenalin
Banks Intercooler and exhaust
In tank and pre-pump mods
Numerous minor Mods
Other Diesels
08 GL 320 CDI
02 VW Golf TDI
3054 Kioti Tractor
Kubota ZD 323
CGMKCM is offline
post #7 of 9 (permalink) Old 05-18-2011, 03:04 PM
crossingdelmar.com
shoaboat's Avatar
I have two of them running off of a OBD splitter and they work great! They say that they will not scan oil temp. But it will. I have the x code for it. Your oil temp will read something wacky like 234degress at cold start but will drop to normal temp at 137 degrees.
1999.5 PSD F350 Crew Dually 2WD, ZF6, 3:54 Dana 80 conversion,Swamps Tunes,H2e,Hypermax Upipes,Swamps Single Shots,6637 Intake,4in Exhaust,Glowshift Gauges,ScanGauge II X units, Ford AIC idle unit, 270 alt,big stereo....
shoaboat is offline
post #8 of 9 (permalink) Old 05-18-2011, 03:46 PM
jones184's Avatar
I like mine. The Xgauge feature really lets you look at a lot of feedback. The scanning is good to. I have some trouble with it staying "connected" some times gets frusterating. I have sent it back once and I am about to do the same to see if they can fix it.
It is awesome for fuel consumption.
2000 7.3 F250 CCLB 4x4
jones184 is offline
post #9 of 9 (permalink) Old 05-18-2011, 10:28 PM Thread Starter
Ouch's Avatar
Are the x gauge codes the guys have over in the 6.0 section the same that I would use on the 7.3?
I tried scanning mine for CEL codes and I couldnt get anything to work... idea what I'm doing wrong?
Ouch is offline
