better rotors - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 05-09-2011, 03:33 AM Thread Starter
Crazy Talk
powerstrokenstang's Avatar
Send a message via AIM to powerstrokenstang
better rotors
what works best slotted, cross drilled or drilled and slotted?
1996 F-250 ex-cab -D60- Motor,fire hoses-Nate,Tuning,Cam-Matt R,P-rods,dummy plugs-Wipe Out,Huffer-Engineered diesel,Carson,Gen3,Idm-Swamps,Rods,studs,fire rings-WOP,Clutch-Valair
455/400's in,S475 T-6 mounted
'84 f-350 2wd, 6.9l, 4spd, drw, flatbed. For Sale
powerstrokenstang is offline
post #2 of 13 (permalink) Old 05-09-2011, 04:31 AM
PSN Mega Miler
crowz's Avatar
Re: better rotors
Stock or slotted. Cross drilled rotors are prone to fractures.
2002 F250 SuperDuty Lariat PSD 7.3 Crew Cab 4x4 302,000+ miles.
, Valvoline Extreme Blue 5w40 Synthetic,
, Clifford Matrix 50.5x Alarm
, P3 Brake Controller, Swamps Injectors, PHP Tunes
crowz is offline
post #3 of 13 (permalink) Old 05-09-2011, 12:29 PM Thread Starter
Crazy Talk
Re: better rotors
ok thanks, i need something that wont warp so easy like the stock ones.
post #4 of 13 (permalink) Old 05-09-2011, 02:36 PM
Reloading
Critical's Avatar
Re: better rotors
Many use power slots and rave about them. I ran the cryo power slots for about 9 a year and they "warped" too. I ended up using NAPA's ultra premium and they seem to be better that the power slots so far.
America Land of the free.*
*Some restrictions may apply, void where prohibited.
Critical is offline
post #5 of 13 (permalink) Old 05-10-2011, 12:22 AM
Towing Doubles with the X
1BadF350's Avatar
Re: better rotors
Call these guys, R1 Concepts out of La Habra, Ca. they also are on Ebay, but you can get the ebay price by calling them, I picked mine up from there store when I was in SoCal. I got there drilled and slotted rotors, along with their recommended pads, and I LOVE my brakes.
I pull a 44' enclosed gooseneck race car trailer and when my factory rotors of 140K miles went metal to metal, I opted for a major overhaul, new calipers front and rear due to the rubber dust boots on the pistons were non-exsistant due to the extreme heat the brakes produced while coming down the mtns out of dever heading to Utah or the 17 frwy from Flagstaff to Phoenix, I run these roads monthly and heavy..
When I replaced the origanal pads and rotors with the R1 Concepts, I also replaced the calipers on all four wheels and upgraded to braided stainless steel brake lines and flushed entire brake system out with new fluid. and I now have the best brakes I have ever had.. Stiff pedal, quick stopping power...Call thee guys, their great guys and parts were instock.. And no-one is harder on brakes then me.
2003 BLACK Excursion LTD 7.3 4x4 4" MBRB Stainless Exhaust, AFE stage II intake, DP F5 Tuner, 4.5" Donahue lift, Rolling on 18" Jesse James Lawless 8's wrapped by 35" Toyo Open Country Mud Terains and airbags,
2002 BLUE F350 XLT 7.3 4x4 CC, BTS Tranny, 6.0 tranny cooler, 4" Silverline Stainless exhaust, S&B intake, DP F6 Tuner with 9 tunes.
1BadF350 is offline
post #6 of 13 (permalink) Old 05-10-2011, 12:24 AM
1BadF350's Avatar
Re: better rotors
And just so you know, my rotors also have the diamond tip slots, and the slots never get packed up with brake pad dust (material) as some have said happens. And the drill holes are champferd also.
1BadF350 is offline
post #7 of 13 (permalink) Old 05-10-2011, 02:45 AM Thread Starter
Crazy Talk
Re: better rotors
thanks i will def look hem up. i had been eyeing summits cross drilled and slotted one. like $100 ea
post #8 of 13 (permalink) Old 05-10-2011, 02:54 AM
PSN Mega Miler
crowz's Avatar
Re: better rotors
Id watch out for the cross drilled ones. They look cool but they crack with age on most of them. If you go cross drilled make sure its a large brand name or good warranty.
crowz is offline
post #9 of 13 (permalink) Old 05-10-2011, 03:09 AM
Caption This
444-4D's Avatar
Re: better rotors
Slots and holes are no benefit until the brake temp gets to about 800 degrees. Most SD brakes never get over 500.
If only those who knew what they were talking about replied, this thread would still be on page one.
2000 F-250 CC 4x4 PSD Auto
444-4D is offline
post #10 of 13 (permalink) Old 05-10-2011, 03:27 AM Thread Starter
Crazy Talk
Re: better rotors
yea thats why i was unsure of what to get. heck after i replaced the rotors on my puller when it was a dd w/ regular replacements i was cracking them once a year. i get tired of them gettin stupid on my sd the first time i haul across mountains after they have been turned. 1badf350 did you get the eline ones or the premium?
